13
Can I disable the yellow (PWR?) LED on the Pi Zero?
I've tried setting the brightness to 0 of led1 (it starts life as 255) and led0 is already 0 but I still get the LED glow.
Out of interest, I only managed to set the brightness file to zero by running the following from /etc/rc.local
echo 0 > /sys/class/leds/led1/brightness
Verified after booting with the following.
$ cat /sys/class/leds/led1/brightness
If I try as the pi user or even via sudo, I get the following error. Even after chmod. Any ideas why?
-bash: /sys/class/leds/led0/brightness: Permission denied
Toby
  • 264
Add the following to /boot/config.txt and reboot.
dtparam=act_led_trigger=none
The LED is wired with inverse logic.
Write 1 to GPIO 47 to switch it off.
Write 0 to GPIO 47 to switch it on.
joan
  • 71,852
  • 76
  • 108
sudo nano /boot/config.txt
There is currently a different way to achieve this on different pi models. You may want to add model filters to config file as followingly:
#Disable Power LED (Red)
[pi3]
dtparam=pwr_led_trigger=none
[pi3+]
[pi4]
dtparam=pwr_led_trigger=default-on
[all]
dtparam=pwr_led_activelow=off
#Disable Activity LED (Green) dtparam=act_led_trigger=none dtparam=act_led_activelow=off
sudo reboot
