i have rpi with jessie release, i can ssh to it through ethernet as i have forced static ip, but i cant ssh to it through wifi. Wifi conection is configured (ssid and psk) and rpi is connected to it. When i execute in my PC command:
nmap -sP 192.168.1.1/24
it finds all devices connected to wifi except raspberry.
I have tryed to force static IP with wifi connection in etc/network/interfaces but then i get no wireless interfaces were found
i have raspberry connected to tv but no keyboard or mouse are available
etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
#iface eth0 inet manual
iface eth0 inet static
address 192.168.1.188
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.1.254
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
result of lsusb:
Bus 001 Device 004: ID 0a5c:bd1e Broadcom Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub`
etc/wpa_supplicant/wpa_supplicant.conf:
update_config=1
network={
ssid="test-network"
psk="testpasswd"
ifconfig:
eth0 Link encap:Ethernet HWaddr b8:27:eb:66:da:a2
inet addr:192.168.1.188 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe66:daa2/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:583 errors:0 dropped:0 overruns:0 frame:0
TX packets:422 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:53261 (52.0 KiB) TX bytes:47466 (46.3 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:243 errors:0 dropped:0 overruns:0 frame:0
TX packets:243 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:21778 (21.2 KiB) TX bytes:21778 (21.2 KiB)
wlan0 Link encap:Ethernet HWaddr fc:b4:e6:bf:a0:d3
inet addr:192.168.1.58 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::feb4:e6ff:febf:a0d3/64 Scope:Link
RX packets:140 errors:0 dropped:2 overruns:0 frame:0
TX packets:49 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:12631 (12.3 KiB) TX bytes:9147 (8.9 KiB)
Problem got kinda solved, still dont know what caused it but here are attempts to fix and fix:
- checked if wifi is enumerated with
lsusb, it was enumerated. - in
etc/network/interfaceschangediface wlan0 inet manualtoiface wlan0 inet dhcp-> reboot. - with dhcp set
no wireless interfaces were found - tryed
sudo service sshd restartgotdhcpcd not runninginfo when hovered over connection icon - in
/etc/ssh/sshd_configuncommented lineListenAddress 0.0.0.0then reboot and try ssh again, didnt work. - checked wifi dongle on windows 7 and ubuntu 14, worked fine, changed charger to 5V/2A, but still didnt solve anything.
These steps should have solved my problem but they didn't, so i copied to desktop and reverted all changes made to wpa-supplicant and interfaces, connected a touchscreen to rpi andconnected with graphic interface by copyiong psk from wpa-supplicant on desktop. Everything worked fine. I compared working wpa supplicant and interfaces with not-working ones but they where identical, dont know what caused my problem but using graphical interface fixed it.
