I'm trying to share the internet connection from a RPi2 connected to internet via wifi to a RPi B+ over ethernet.
I want to use static ip addresses for simplicity.
So RPi2 ("master") is 10.0.0.1 and RPi B+ ("slave") is 10.0.0.2.
I've configured the /etc/network/interfaces as following:
RPi2
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet static
    address 10.0.0.1
    gateway 10.0.0.1
    netmask 255.255.255.0
    broadcast 10.0.0.0
auto wlan0
iface wlan0 inet dhcp
    wpa-ssid "XXX"
    wpa-psk "YYY"
iface default inet dhcp
RPi
auto lo
auto eth0
allow-hotplug eth0
    address 10.0.0.2
    gateway 10.0.0.1
    broadcast 10.0.0.0
I've also applied some rules to iptables on RPi2:
Chain FORWARD (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             10.0.0.0/24         state RELATED,ESTABLISHED
ACCEPT     all  --  10.0.0.0/24         anywhere
Chain POSTROUTING (policy ACCEPT)
MASQUERADE  all  --  10.0.0.0/24        !10.0.0.0/24
The /etc/resolv.conf on the "slave" machine is set to nameserver 10.0.0.1 I can ping successfully each other machine, the "master" can access the internet, but when I try to ping google.com from the "slave" I get this error:
ping: unknown host google.com
Any idea how can I make it working?
Thanks
Your need is a little bit more complicated that what it looks; to share your WI-FI connection on wlan0 with one (or more) devices, you may need a physical Ethernet switch, so both Ethernet (I'm not sure is you can just connect the Ethernet port as peer-to-peer)
Install dnsmasq: you will create a dns and dhcp servers, however you can still use fixed ip's on your clients; the goal is to have DNS/DHCP on the Ethernet side and a floating (public IP) on WLAN
apt-get install -y dnsmasq dnsutils
after the install just a few changes to the dnsmasq config file.
nano /etc/dnsmasq.conf
#dhcp-range=192.168.0.50,192.168.0.150,12h
dhcp-range=10.0.0.10,10.0.0.99,12h
# add the google server
server=8.8.8.8
# change your domain name
domain=home
# uncommented so, the local files will be tried here
local=/home/
# uncomment
interface=eth0
Reboot and you will be able to share your wifi.
fcm
  • 1,869
  • 30
Simply calling a machine a DNS server does not make it one. Try nameserver 8.8.8.8 (google's free public ones). If that works, you could try the actual router address (can't promise it will work, but it might), or if you want to get fancy, transfer the resolv.conf from the master after the connection is established (maybe if-up scripts can do that).
If dhcpd turns out to be running on the slave it may complicate this and you probably want to disable that as it serves no purpose.
