I am trying to get blue tooth working on my Raspberry Pi using the latest Raspbian image and the Qt 5.6 source. After recompiling twice (which takes about 35 hours) I keep getting the following error:
Either no Qt D-Bus found or no BlueZ headers.
I have used Native Build of Qt5 on a Raspberry Pi in order to get everything compiled. I have also installed the following blue tooth packages:
  • bluez
  • libbluetooth3
  • libbluetooth-dev
  • libdbus-c++-dev
I found a similar thread Bluetooth on Arm (Raspberri PI Debian 7) in which I tried all the possible solution but nothing seems to work so far.
If I run qmake -d on the qt5/qtconnectivity/config.tests/bluez files I get the following output at the very end:
/usr/local/qt5/mkspecs/features/link_pkgconfig.prf:8: calling built-in $list(bluez) /usr/local/qt5/mkspecs/features/link_pkgconfig.prf:8: entering loop for PKGCONFIG_LIB over bluez
/usr/local/qt5/mkspecs/features/link_pkgconfig.prf:8: loop iteration "bluez" /usr/local/qt5/mkspecs/features/link_pkgconfig.prf:8: entering block /usr/local/qt5/mkspecs/features/link_pkgconfig.prf:10: NOT /usr/local/qt5/mkspecs/features/link_pkgconfig.prf:10: evaluating test function "packagesExist"
/usr/local/qt5/mkspecs/features/link_pkgconfig.prf:10: calling packagesExist(bluez) /usr/local/qt5/mkspecs/features/qt_functions.prf: entering block /usr/local/qt5/mkspecs/features/qt_functions.prf:191: evaluating test function "contains"
/usr/local/qt5/mkspecs/features/qt_functions.prf:191: calling built-in contains(QT_CONFIG, no-pkg-config) /usr/local/qt5/mkspecs/features/qt_functions.prf:191: test function returned true /usr/local/qt5/mkspecs/features/qt_functions.prf:191: AND /usr/local/qt5/mkspecs/features/qt_functions.prf:191: flow control statement 'return', aborting block
/usr/local/qt5/mkspecs/features/link_pkgconfig.prf:10: test function returned false /usr/local/qt5/mkspecs/features/link_pkgconfig.prf:10: AND /usr/local/qt5/mkspecs/features/link_pkgconfig.prf:10: evaluating test function "error"
/usr/local/qt5/mkspecs/features/link_pkgconfig.prf:10: calling built-in error("bluez development package not found") Project ERROR: bluez development package not found
but when I run the command pkg-config --modversion bluez it returns version 5.36 which would suggest it is able to find something. Running pkg-config --libs returns -L/usr/local/lib -lbluetooth.
Is there anyone who might know what causes my problems.
Steve Robillard
  • 34,988
  • 106
  • 110
Encya
  • 61
Looking through the beginning of that Qt-Bug report I notice that you do not seem to have installed the libdbus-1-dev package that gets mentioned.
SlySven
  • 3,631
  • 46
