I just finished installed Jasper in a RPi 2, Im using google's TTS STT, and when I'm trying to run the service
$/home/pi/jaspter/jasper.py
I get the following error:
No handlers could be found for logger "cmuclmtk"
* JASPER - THE TALKING COMPUTER *
* (c) 2015 Shubhro Saha, Charlie Marsh & Jan Holthuis *
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.front.0:CARD=0'
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.bcm2835.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
File "/home/pi/jaspter/jasper.py", line 148, in <module>
app.run()
File "/home/pi/jaspter/jasper.py", line 115, in run
self.mic.say(salutation)
File "/home/pi/jaspter/client/mic.py", line 262, in say
self.speaker.say(phrase)
File "/home/pi/jaspter/client/tts.py", line 471, in say
tts.save(tmpfile)
File "/usr/local/lib/python2.7/dist-packages/gtts/tts.py", line 90, in save
self.write_to_fp(f)
File "/usr/local/lib/python2.7/dist-packages/gtts/tts.py", line 108, in write_to_fp
r.raise_for_status()
File "/usr/local/lib/python2.7/dist-packages/requests/models.py", line 840, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 503 Server Error: Service Unavailable for url: http://translate.google.com/translate_tts?textlen=30&idx=0&q=How+can+I+be+of+service%2C+Luis%3F&tl=en&client=t&total=1&ie=UTF-8
There are a bunch of errors but I think the most important is the last one, with the HTTPError: 503, is there a problem connecting to the google speech API?? Anyone has had this problem?
