Raspberry PI 2 was the best christmas present this year, but I’m having some serious issues with the wi-fi connection setup. I manage to connect only with ethernet cable.
I also noticed a weird behavior of the internet connection: after a couple of minutes the raspberry is turned on the internet connection dies on every other device. It’s like the raspberry vampirizes the internet connection everywhere! Initially I thought it was a coincidence, but it happens almost everytime, so I think the two things are related.
I tried a lot of solutions I found (and understood) online, but I didn’t manage to make them work. Consider, please, I’m new to Raspberry and to Raspbian/Debian/Linux (I worked for a year on a PC with Ubuntu a couple of years ago, but I never had problems that I couldn’t resolve with 10 minutes on google).
The Wi-fi stick is being picked up and the stick modules are loaded (I think), here’s the result of lsmod:
Module                  Size  Used by
arc4                    1753  2
rt2800usb              17716  0
rt2800lib              71860  1 rt2800usb
rt2x00usb               8545  1 rt2800usb
rt2x00lib              36817  3 rt2x00usb,rt2800lib,rt2800usb
mac80211              541952  3 rt2x00lib,rt2x00usb,rt2800lib
cfg80211              419759  2 mac80211,rt2x00lib
crc_ccitt               1161  1 rt2800lib
rfkill                 16659  2 cfg80211
bcm2835_gpiomem         3023  0
evdev                  10226  6
joydev                  9047  0
snd_bcm2835            19739  3
snd_pcm                74833  1 snd_bcm2835
snd_timer              18164  1 snd_pcm
snd                    52116  9 snd_bcm2835,snd_timer,snd_pcm
uio_pdrv_genirq         2966  0
uio                     8228  1 uio_pdrv_genirq
i2c_dev                 6040  0
fuse                   81721  3
ipv6                  341380  30
Here’s the result of ifconfig -a
eth0  Link encap:Ethernet  HWaddr b8:27:eb:35:ca:ef
      inet6 addr: fe80::397a:2c60:ef27:a17d/64 Scope:Link
      UP BROADCAST MULTICAST  MTU:1500  Metric:1
      RX packets:0 errors:0 dropped:0 overruns:0 frame:0
      TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo    Link encap:Local Loopback
      inet addr:127.0.0.1  Mask:255.0.0.0
      inet6 addr: ::1/128 Scope:Host
      UP LOOPBACK RUNNING  MTU:65536  Metric:1
      RX packets:248 errors:0 dropped:0 overruns:0 frame:0
      TX packets:248 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:0
      RX bytes:20832 (20.3 KiB)  TX bytes:20832 (20.3 KiB)
wlan0 Link encap:Ethernet  HWaddr 00:0f:60:08:d8:e4
      inet addr:192.168.1.7  Bcast:192.168.1.255  Mask:255.255.255.0
      inet6 addr: fe80::20f:60ff:fe08:d8e4/64 Scope:Link
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:31 errors:0 dropped:0 overruns:0 frame:0
      TX packets:84 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:4609 (4.5 KiB)  TX bytes:17260 (16.8 KiB)
My interfaces file looks like this:
auto wlan0
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet dhcp
iface default inet dhcp
And this is my wpa_supplicant.conf (yes, I’m absolutely sure the login and password are correct: I checked them a thousand times and tested them on other devices, they work)(hidden here):
network={
    ssid="my id"
    psk="my password"
Thanks everyone!
Edit: I'm adding some (I hope useful) information: When i ping www.google.com i get unknown host. When i ping 8.8.8.8 i get data:
64 bytes from 8.8.8.8: icmp_seq=1 ttl=53 time=48.4 sec
(etc)
Pippilotta
I had a similar problem with a Netgear dongle. It worked after I added key_mgmt=WPA-PSK to the network definition in /etc/wpa_supplicant/wpa_supplicant.conf.
This is exactly what my /etc/network/interfaces contains:
auto lo
auto eth0
allow-hotplug eth0
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
This is how my /etc/wpa_supplicant/wpa_supplicant.conf looks like:
update_config=1
network={
        ssid="MY_NETWORK_NAME"
        psk="my_key"
        key_mgmt=WPA-PSK
The only thing I changed here in the example are my ssid and psk. I'm not sure it's needed, but like in the example, those values are in double quotes. Use your own values for ssid and psk.
