The unpacking message does note that you are installing the same version as was previously in place - which I guess is not surprising if you are trying to reinstall it. Given that this package is not vital for normal operation of the Pi I'd suggest:
sudo apt-get --fix-broken --reinstall install gitlab-ce
this does assume that nothing else is broken. If there ARE other issues I'm a great fan of using aptitude rather than apt-get; its interactive mode (uses ncurses-type screen and is the default if no command line arguments given) can be a help in working out what is/or will be going on when you type g (for "Go") to make the changes selected - in case it is not clear how to start there use Ctrl+t to access the menu line at the top.
EDIT: The OP reported that this was not enough, so I will suggest a "bigger-hammer":
sudo dpkg --force-depends --remove gitlab-ce
The first argument tells dpkg (the underlying package manager that apt-get and aptitude talk with) to remove the package even if there are things that depend on it and that would be broken if it was taken away - this should be OK as we are aiming to put it back shortly.
Now we could try and remove the local copy of the package - just in case there was something funky about it - I would expect it to be located in the /var/cache/apt/archives directory. You would be looking for a file called gitlab-ce-XXX.deb where XXX is a version code of some sort.
Finally we can try again from scratch:
sudo apt-get install gitlab-ce
The following may be of help, in order they do:
sudo apt-get update - ensure we have an updated list of packages
sudo apt-get check - check the system for broken/missing packages
sudo apt-get -f install - repair anything reported by the previous check
Note: Reviewing the OP's link to the gitlab site - the step by step instructions talk about "2. Add the GitLab package server and install the package" however the command they provide creates a gitlab_ce.list file in the correct /etc/apt/sources.list.d/ directory with a reference to wheezy not jessie as the distribution version - I cannot help thinking that is an issue here considering the OP's assertion they are using Jessie - I'd follow that up with the package creators!
