23
I have read quite a bit about how to compile a kernel module on (and for) the Raspberry Pi, but I'm still not quite able to figure out why it's not working. I have been able to build the module, but it reports Invalid module format when I try to insmod the result. Here is the process I followed. First, as root under /root I executed the following shell script:
getKernel.sh
#! /usr/bin/bash
FIRMWARE_HASH=$(zgrep "* firmware as of" /usr/share/doc/raspberrypi-bootloader/changelog.Debian.gz | head -1 | awk '{ print $5 }')
KERNEL_HASH=$(wget https://raw.githubusercontent.com/raspberrypi/firmware/$FIRMWARE_HASH/extra/git_hash -O -)
git clone https://github.com/raspberrypi/linux
cd linux
git checkout $KERNEL_HASH
wget https://raw.githubusercontent.com/raspberrypi/firmware/$FIRMWARE_HASH/extra/Module.symvers
zcat /proc/config.gz >.config
make oldconfig
make modules_prepare
ln -s /root/linux /lib/modules/$(uname -r)/build
The first few lines are from http://lostindetails.com/blog/post/Compiling-a-kernel-module-for-the-raspberry-pi-2
The rest I wrote to automate more of the process. Once all of that runs successfully, I have the source that should exactly match the running kernel, the configuration to match and a symlink. There were some redirects from the github web location (apparently it's now https://raw.githubusercontent.com/ ) but no actual errors.
Then I become the default pi user and in a directory named /home/pi/projects/lkm I have this source code for a very simple toy module:
hello.c
#include <linux/init.h>
#include <linux/kernel.h>
#include <linux/module.h>
MODULE_LICENSE("GPL");
MODULE_DESCRIPTION("Do-nothing test driver");
MODULE_VERSION("0.1");
static int __init hello_init(void){
   printk(KERN_INFO "Hello, world.\n");
   return 0;
static void __exit hello_exit(void){
   printk(KERN_INFO "Goodbye, world.\n");
module_init(hello_init);
module_exit(hello_exit);
Finally, I build the module with this Makefile
Makefile
MODSRC=/home/pi/projects/lkm
obj-m+=hello.o
all:
    make -C /lib/modules/$(shell uname -r)/build M=${MODSRC} modules
clean:
    make -C /lib/modules/$(shell uname -r)/build M=${MODSRC} clean
Finally, I attempt to load the module:
sudo insmod hello.ko
The result, however, is disappointing:
insmod: ERROR: could not insert module hello.ko: Invalid module format
Possibly relevant details
I'm using the currently latest jessie version of Raspbian on a Raspberry Pi2.
$ uname --kernel-release --kernel-version
4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015
$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.9/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Raspbian 4.9.2-10' --with-bugurl=file:///usr/share/doc/gcc-4.9/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.9 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.9 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libitm --disable-libquadmath --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.9-armhf/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.9-armhf --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.9-armhf --with-arch-directory=arm --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
Thread model: posix
gcc version 4.9.2 (Raspbian 4.9.2-10)
Unfortunately, I'm not sure how to further troubleshoot this or fix it. Any clues?
Jacobm001
  • 11,904
  • 47
  • 58
Edward
  • 961
  • 25
First of all, make sure you use the proper kernel headers. I assume that your kernel headers and source code are more updated than the kernel you're running.
Try to do an apt-get update && apt-get upgrade then reinstall the module. If the problem persists, triple check that your kernel headers match your current kernel, recompile again then try to install.
Note: I'm using Jessie.
UPDATE: Run these as root.
# The usual update routine
apt-get update -y
apt-get upgrade -y
# Update the kernel!
rpi-update
You may need to reboot. After that, proceed with the commands below, still using the root account.
# Get rpi-source
sudo wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source -O /usr/bin/rpi-source
# Make it executable
sudo chmod +x /usr/bin/rpi-source
# Tell the update mechanism that this is the latest version of the script
/usr/bin/rpi-source -q --tag-update
# Get the kernel files thingies.
rpi-source
If rpi-source throws a GCC error (something about a version mismatch), it's okay as long as your current GCC version is higher. Run rpi-source --skip-gcc instead of rpi-source
Then, proceed with your Hello World example. Create the folder and cd into it. Then, create the files.
mkdir hello
cd hello
Files:
hello.c
int hello_init(void)
    pr_alert("Hello World :)\n");
    return 0;
void hello_exit(void)
    pr_alert("Goodbye World!\n");
Makefile (case-sensitive?)
obj-m := hello.o
Now that you have your files, you can go ahead and run the usual Hello World build commands:
make -C /lib/modules/$(uname -r)/build M=$(pwd) modules
insmod hello.ko
You should now check dmesg. The last line should print Hello World :) highlighted in red.
If you do, congratulations. You just made and installed a kernel module.
Now remove it using rmmod hello. dmesg should now print Goodbye World! highlighted in red.
Sources: 1 2 3
Aloha
  • 7,176
  • 29
  • 52
There is a much simpler version here, tested on jessie and stretch.
sudo apt-get install raspberrypi-kernel-headers
and then when your files are in place :
Example
Create the hello directory, go inside and create the following files : hello.c and Makefile.
I recommend working as your normal user, not root, only insmod, rmmod, and make modules_install commands require root permissions, and the necessary sudo is shown in the following commands.
hello.c (unchanged, your file)
   return 0;
Makefile (changed)
obj-m+=hello.o
all:
    make -C /lib/modules/$(shell uname -r)/build M=$(pwd) modules
clean:
    make -C /lib/modules/$(shell uname -r)/build M=$(pwd) clean
modules_install: all
    $(MAKE) -C $(KERNEL_SRC) M=$(SRC) modules_install
    $(DEPMOD)
Usage
  • Build : make (in the same directory as the Makefile)
  • Test
    • Insert the module with sudo insmod hello.ko
    • Find Hello World :) in the output of dmesg
    • Remove the module with sudo rmmod hello
    • Find Goodbye, world. int the output of dmesg
  • Install, when your module is working, sudo make modules_install will install the module where it belongs, so modprobe will work.
Aurora0001
  • 6,357
  • 25
  • 39
pim
  • 622
in getKernel.sh file add
sudo modprobe configs
before
(now in default rpi image /proc/config.gz not exist)
