I got stacked. I have a Raspberry Pi 2 Model B with OSMC installed on it. I want to connect an external drive (Seagate Backup Plus 1TB) to it.
I connected it through a usb hub and there is an additional power source connected to RPi. But my RPi can't see the hard drive.
If I type sudo fdisk -l I get:
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 499711 497664 243M c W95 FAT32 (LBA)
/dev/mmcblk0p2 501760 3854335 3352576 1.6G 83 Linux
As you can see there is no Seagate hard drive.
What am I supposed to do?
dmesg:
[ 3720.753243] usb 1-1.4.3: new full-speed USB device number 12 using dwc_otg
[ 3720.859765] usb 1-1.4.3: not running at top speed; connect to a high speed hub
[ 3720.869524] usb 1-1.4.3: New USB device found, idVendor=0bc2, idProduct=ab21
[ 3720.869558] usb 1-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3720.869576] usb 1-1.4.3: Product: BUP Slim BK
[ 3720.869591] usb 1-1.4.3: Manufacturer: Seagate
[ 3720.869607] usb 1-1.4.3: SerialNumber: NA7805B4
[ 3720.871294] usb-storage 1-1.4.3:1.0: USB Mass Storage device detected
[ 3720.873274] usb-storage 1-1.4.3:1.0: Quirks match for vid 0bc2 pid ab21: 2000000
[ 3720.881189] scsi host5: usb-storage 1-1.4.3:1.0
[ 3721.886536] scsi 5:0:0:0: Direct-Access Seagate BUP Slim BK 0143 PQ: 0 ANSI: 6
[ 3721.888811] sd 5:0:0:0: Attached scsi generic sg0 type 0
[ 3721.896262] sd 5:0:0:0: [sda] Spinning up disk...
[ 3727.383243] ....................
[ 3747.558453] usb 1-1.4.3: USB disconnect, device number 12
