According to the example from:
How can I start X11 only for a single application?
I'm running python script that shows Tkinter frame by invoking:
startx ./script.py
... when the script is done, it exits with:
root.destroy() # Tk() from Tkinter
sys.exit(0)
... however X server seems still to be running (blank screen is displayed and I have to use Ctrl+C to get access to the console back).
How can i make xserver stopped immediatelly when following application exits?
EDIT: I've noticed that if i didn't use MyThread (but e.g. timer handler method), closing X windows session works fine. Also this script finishes properly when run (tested) on Windows.
Code with issue:
#!/usr/bin/env python
import sys
import threading
import time
from Tkinter import Tk, Frame, BOTH
SCREEN_RES = "1024x600"
DELAY = 1000
TK_ROOT = Tk()
class MyThread(threading.Thread):
    def run(self):
        try:
            print "Entering MyThread..."
            time.sleep(3)
            print "Exiting MyThread..."
            TK_ROOT.destroy()
            sys.exit(0)
        except KeyboardInterrupt:
            exit()
# noinspection PyAttributeOutsideInit
class SysInfo(Frame):
    mt = MyThread()
    def __init__(self, parent):
        Frame.__init__(self, parent, background="gray")
        self.parent = parent
        self.init_ui()
        self.after(DELAY, self.on_timer)
        self.mt.start()
    def init_ui(self):
        self.parent.title("SomeFrame")
        self.pack(fill=BOTH, expand=True)
    def on_timer(self):
        print("Timer fired.")
def main():
    TK_ROOT.geometry("%s+0+0" % SCREEN_RES)
    SysInfo(TK_ROOT)
    TK_ROOT.mainloop()
main()
alwi
  • 131
According to the flipping manual, which I hope you have found the chance to read, normally startx(1) will look in order for ~/.xinitrc then in the xinit library directory for a system default xinitrc script to run - but as you have provided command line client arguments instead (./script.py) that is used instead. You might find it instructive to look for the system wide script for clues as to how things are normally done.
I think you may get somewhere with further arguments after a -- on the line that you use, arguments after that symbol are server arguments, one of which may be relevant is -terminate which according to the X server command line help:
causes the server to terminate at server reset, instead of continuing to run. This overrides a previous -noreset command line option.
Perhaps this can give some possible pointers...
SlySven
  • 3,631
  • 46
