I have the Official Raspberry Pi Wifi Adaptor on Raspbian Jessie. I can scan and connect to wifi just fine but I would like to get it to connect at boot so I can instantly use the SSH and VNC servers rather than a HDMI cable and monitor.
Does anyone know how I could get the RPi to make the connection at boot?
Thanks.
If you configure the WiFi connection via /etc/wpa_supplicant/wpa_supplicant.conf, it should automatically connect - example file contents:
update_config=1
network={
#Set wifi network name and password here
ssid="NAME"
psk="PASSWORD"
# Protocol type can be: RSN (for WP2) and WPA (for WPA1)
#proto=WPA2
# Key management type can be: WPA-PSK or WPA-EAP (Pre-Shared or Enterprise)
#key_mgmt=WPA-PSK
# Pairwise can be CCMP or TKIP (for WPA2 or WPA1)
#pairwise=TKIP
#Authorization option should be OPEN for both WPA1/WPA2 (in less commonly used are SHARED and LEAP)
#auth_alg=OPEN
You may need to set a static IP address though, otherwise the Pi may have a different IP address to the one you are expecting
Alternatively, if your WiFi hardware supports it, you get the Pi to make a wireless hotspot which devices could then connect to - this may use more power though (so it will drain batteries quicker etc).
Wilf
  • 2,533
  • 39
