Has anyone had good results on overclocking the PiZero? If so what speeds where achieved?
raspi-ninja
  • 889
The Pi Zero uses the same silicon as Pi 1, so they have the same top speed 1GHz. Pi 1 came with a more conservative clock speed but Pi Zero came already maxed out, so it makes no sense to overclock Pi Zero (but on the other way Pi 1 should be able to be cranked to Pi Zero levels.)
Maxthon Chan
  • 1,051
According to a comment on the Pi Foundation's blog post announcing the recent Raspbian update, due to a bug you should not overclock your Pi Zero. It will actually slow it down.
Simon Long says: 2nd Dec 2015 at 1:57 pm
On Pi Zero, you should just leave overclocking set to “None” (which selects the default clock speeds set for the device in the firmware, i.e. 1GHz on the Zero) – all the other options will actually slow your Pi Zero down! This will be corrected in the next release – Pi Zero basically comes out of the box running as fast as it is safe to run it.
Steve Robillard
  • 34,988
  • 106
  • 110
I think you can overclock it but it is actually underclocking if you overclock with the default settings because they are for the Pi 1 which has a slower default clock. If you edit config.txt you may be able to go higher but if you want to be really safe use a heatsink.
I have overclocked my Pi zero w upto 1.1ghz at 47 degrees celsius without any heatsink or cooling fan. It is possible to overclock without any cooling upto 1.5ghz(i cannot provide the source, it is a portuguese website where people have competitions on overclocking the pi). The highest reached is 1.62ghz with water cooling. Just fiddle with the config file!(you might damage a few sd cards in this process)
Thomas
