I use a static IP for my RPi:
root@rpi2:/etc# cat /etc/network/interfaces
auto lo
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet static
        address 192.168.0.2
        netmask 255.255.255.0
        gateway 192.168.0.254
        wpa-essid myssid
        wpa-psk mykey
        dns-nameservers 192.156.0.254
/etc/resolv.conf (which is a plain file, not a link) gets rewritten at each reboot with
# Generated by resolvconf
nameserver 127.0.0.1
I do not even have resolvconf installed!
root@rpi2:~# aptitude search resolvconf
p   resolvconf  - name server information handler
How can I disable this overwriting? (short of chattr +i which is an ugly hack)
WoJ
  • 543
6 Answers6
It looks like I found the issue. /bin/dhcpcd was still running despite no interfaces being configured via DHCP. The culprit is dhcpcd5.
Removing the package helped (and, surprise, something called openresolv was included)
root@rpi2:~# aptitude purge dhcpcd5
The following packages will be REMOVED:
  dhcpcd5{p} openresolv{u}
/etc/resolv.conf is not overwritten anymore.
WoJ
  • 543
Instead of removing dhcpcd and breaking a bunch of stuff, you could configure /etc/dhcpcd.conf (and probably /etc/init.d/dnsmasq) with your DNS information...
Just sayin'
ghosts
  • 71
Open /etc/dhcp/dhclient.conf and input a line starting with supersede. This line makes sure that only the supplied list of values for domain-name-servers on it's right will be written inside /etc/resolv.conf when writing event happens.
Example:
supersede domain-name-servers 127.0.0.1, ::1;
WoJ
  • 543
71GA
  • 126
You could just disable the service resolved by entering: sudo systemctl disable systemd-resolved.service
It may be simple as putting it's permissions to read-only.
sudo chmod 440 /etc/resolv.conf
But I would suggest to check again what is causing your resolv.conf to be overwritten as setting it to read-only may cause some other unexpected things.
10robinho
  • 726
I found this similar question for Unix. The solution does not require to remove the dhcpd5 package.
However, I have not yet figured out where the config files for dhcpd are hiding on my Pi/Jessie. There are several suggestions here, I'll try the one where you add fixed DNS addresses at the end of the /etc/dhcpcd.conf.
Will keep you posted.
YAG
  • 101
