9
I am trying to get my Raspberry Pi to read some audio input through a basic USB souncard and play it back in real time for 10 seconds, and then print the output with Matplotlib after it's finished. I am using PyAudio in callback mode. Audio recording and playback works fine in Audacity.
import pyaudio
import time
import numpy as np
from matplotlib import pyplot as plt
import scipy.signal as signal
CHANNELS = 1
RATE = 44100
p = pyaudio.PyAudio()
fulldata = np.array([])
dry_data = np.array([])
def main():
stream = p.open(format=pyaudio.paFloat32,
                channels=CHANNELS,
                rate=RATE,
                output=True,
                input=True,
                stream_callback=callback)
stream.start_stream()
while stream.is_active():
    time.sleep(10)
    stream.stop_stream()
stream.close()
numpydata = np.hstack(fulldata)
plt.plot(numpydata)
plt.title("Wet")
plt.show()
numpydata = np.hstack(dry_data)
plt.plot(numpydata)
plt.title("Dry")
plt.show()
p.terminate()
def callback(in_data, frame_count, time_info, flag):
    global b,a,fulldata,dry_data,frames
    audio_data = np.fromstring(in_data, dtype=np.float32)
    dry_data = np.append(dry_data,audio_data)
    #do processing here
    fulldata = np.append(fulldata,audio_data)
    return (audio_data, pyaudio.paContinue)
main()
After I run my code I can see the the plotted output signal, but it only has very few samples. I can't hear anything through the speakers either while I'm playing. Running the same code on my Windows machine works fine, using the same Python and PyAudio versions. Audio Output
I have set my USB audio card as default in etc/modprobe.d/alsa-base.conf.
Any help would be much appreciated !
DrumPower3004
  • 105
I do not know why your audio is not working. Perhaps you need to explicitly state the output device index.
This is what I did to get audio out through the RPi audio jack.
#!/usr/bin/python
# tone.py   play a tone on raspberry pi
import myPyLib   # get control-C handler
import time
import math
import pyaudio
from numpy import linspace,sin,pi,int16
pa = None;
s  = None;
def init_audio(rate=8000):
  global pa,s
  print "init_audio: Create PyAudio object"
  pa = pyaudio.PyAudio()
  print "init_audio: Open stream"
  s = pa.open(output=True,
            channels=1,
            rate=rate,
            format=pyaudio.paInt16,
            output_device_index=0)
  print "init_audio: audio stream initialized"
def close_audio():
  global pa,s
  print "close_audio: Closing stream"
  s.close()
  print "close_audio: Terminating PyAudio Object"
  pa.terminate()
def note(freq, len, amp=5000, rate=8000):
 t = linspace(0,len,len*rate)
 data = sin(2*pi*freq*t)*amp
 return data.astype(int16) # two byte integers
def tone(freq=440.0, tonelen=0.5, amplitude=5000, rate=8000):
  global s
  # generate sound
  tone = note(freq, tonelen, amplitude, rate)
  # play it
  #print "tone.main(): start playing tone"
  s.write(tone)
# ##### MAIN ######
def main():
  myPyLib.set_cntl_c_handler(close_audio)  # Set CNTL-C handler
  # open audio channel
  init_audio()
  # play tones forever
  print "tone.main(): start playing tones"
  while True:
    print "tone.main: tone() 440"
    tone()
    time.sleep(3)
    print "tone.main: tone(261)"
    tone(261,1)
    time.sleep(3)
    print "tone.main: tone(880)"
    tone(880)
    time.sleep(3)
if __name__ == "__main__":
    main()
There is a 20 second delay opening the stream, but then there is no delay.
pi@raspberrypi:~/RWP $ ./tone.py
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
^C
** Control-C Detected
goobering
  • 10,750
  • 40
  • 64
Alan McDonley
  • 66
