I have Raspbian Jessie on RPI 2 B, I cannot set my wired NIC with a static IP address.
I have uninstalled raspberrypi-net-mods ifplugd, because have a lot of stability issues and insists on uses dhcpcd.....
Now it works fine, but it uses isc-dhcp-client , and I don't want it.
My configuration
root@raspberrypi:~# egrep -v "#|^$" /etc/network/interfaces
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet static
        address 192.168.80.148
        netmask 255.255.255.0
        gateway 192.168.80.1
        dns-nameservers 192.168.80.1
Logs show as follows:
Nov 26 18:04:58 raspberrypi systemd[30657]: Starting Default.
Nov 26 18:04:58 raspberrypi systemd[30657]: Reached target Default.
Nov 26 18:04:58 raspberrypi systemd[30657]: Startup finished in 37ms.
Nov 26 18:04:58 raspberrypi systemd[1]: Started User Manager for UID 0.
Nov 26 18:05:01 raspberrypi CRON[30683]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Nov 26 18:07:51 raspberrypi dhclient: DHCPREQUEST on eth0 to 192.168.80.1 port 67
Nov 26 18:07:51 raspberrypi dhclient: DHCPACK from 192.168.80.1
Nov 26 18:07:51 raspberrypi systemd[1]: Reloading LSB: start Samba SMB/CIFS daemon (smbd).
Nov 26 18:07:51 raspberrypi smbd[30752]: Reloading /etc/samba/smb.conf: smbd.
Nov 26 18:07:51 raspberrypi systemd[1]: Reloaded LSB: start Samba SMB/CIFS daemon (smbd).
Note I've tried auto instead allow-hotplug but if I reboot router which RPI is plugged it lost its link and I have to poweroff in a dirty way... And logs showing that it is using DHCP:
Any ideas?
sebelk
  • 161
I'm still not fully up with systemd, however if you run
sudo service networking status
Do you get a message like
Warning: Unit file changed on disk, 'systemctl daemon-reload' recommended.
I did after editing /etc/network/interfaces
If so, run
sudo systemctl daemon-reload
Jaromanda X
  • 2,481
