I am currently running a web-facing server with the root filesystem on an external USB disk with another USB disk attached and destined for backup of the server.
What I really need to do, however, is to have a full backup system running as a scheduled cron task, with incremental backups and/or compression, as well as an easy to run restore procedure or script.
My setup is as follows:
/dev/mmcblk0p1: LABEL="PI BOOT" UUID="6654-8624" TYPE="vfat"
/dev/sda1: LABEL="rootfs" UUID="6d300a32-1cd7-46ab-be6f-c30c2bc51519" TYPE="ext4"
/dev/sdb1: LABEL="The Pad Backup" UUID="ec33414c-b925-d101-a012-404cb925d101" TYPE="ext4"
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       917G  3.9G  867G   1% /
devtmpfs        459M     0  459M   0% /dev
tmpfs            93M  1.4M   92M   2% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           186M     0  186M   0% /run/shm
/dev/mmcblk0p1  968M   40M  929M   5% /boot
none            463M     0  463M   0% /sys/fs/cgroup
Please note: This is not about backing up an SD card
Any help would be greatly appreciated.
Cheers, Jack
Pi Hard
