I have the Epiphany web browser running 24/7 to display up-to-date weather on a monitor from WeatherUnderground but it keeps on crashing by next morning.
I am not sure how to figure out what is causing this. Sometimes you have to also reboot the device in order to relaunch the browser. Could this be a memory issue?
EDIT:
grep "oom-killer" /var/log/syslog*
returned no results.
EDIT 2:
Tried this as well: https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=118118
What I noticed was the browser did not crash after using EDIT 2 but now it just hangs and does use up most if not all the system memory.
GPU Memory has also been set at 256MB of Ram
EDIT 3: Edit2 did not work. Edit1 seems to have caused the crashes to happen more often.
Jason
  • 241
You could try an hourly run of the command free -mht.
Something like the below example and placing this executable under /etc/cron.hourly. Files must not have .extensions.
#!/bin/bash
free -mht >> /tmp/memoryuse >/dev/null 2>&1
You could also try increasing gpu_mem allocation in the /boot/config.txt
