My SQLite project is working on Raspberry Pi 2 (with all function insert, delete, update ..) but where are my SQLite database files located?
I followed this way I found my SQLite database location on when I compiled on x86 - localmachine:
My SQLite project VS 2015
Package.appxmaifest\Packaging\Package name : 9fd5092f-7eb0-4607-bc31-e41f02c4f1e4
and
C:\Users\computerName\AppData\Local\Packages\PackageName\LocalState
That path contains my SQLite DB files.
But when I compile ARM - RemoteMachine I can't find my SQLite database file on Windows IOT OS device RPi2 (in the SD card).
mpromonet
  • 1,124
  • 38
brhmbzky
One way to do it is to specify the path of the actual file (using package SQLite.Net-PCL - You didn't say what package you are using)
path = Path.Combine(Windows.Storage.ApplicationData.Current.LocalFolder.Path, "db.sqlite");
conn = new SQLite.Net.SQLiteConnection(new SQLite.Net.Platform.WinRT.SQLitePlatformWinRT(), path);
Print out the path somewhere and you should be able to find it. Its possible the default path is buried somewhere deep.
Piotr Kula
  • 17,336
  • 66
  • 105
