I'm working with a raspberry 2 running Arch
Linux a4h-rpi2-arch 4.1.12-1-ARCH #1 SMP PREEMPT Tue Oct 27 19:16:16 MDT 2015 armv7l GNU/Linux
I got some problem to display float on cout using c++ streams. Here is a simple main :
#include <iostream>
using namespace std;
int main() {
float f;
f = 9.87654321f;
cout << f << endl;
f = 987.654321f;
cout << f << endl;
f = 987654.321f;
cout << f << endl;
f = 9876543.21f;
cout << f << endl;
f = 0.0000987654321f;
cout << f << endl;
return 0;
i cross compiled it with raspberry toolchain :
arm-bcm2708-linux-gnueabi-g++ -o /tmp/test_stream /tmp/test.cpp
Here is result :
test_stream
Now if I compile it with
arm-bcm2708hardfp-linux-gnueabi-g++ -o /tmp/test_stream /tmp/test.cpp
I get correct results :
test_stream
9.87654
987.654
987654
9.87654e+06
9.87654e-05
In first case I'm only using software to perform float calculations. I shouldn't have any differences in result between 2 toolchain? Only compute time should be better using hard float hw unit?
lah
rem
  • 183
No; since the executable is dynamically linked to the system library on a platform with hardware floating point support, there is no facility to perform such calculations with software.
At least, that's my guess. I think it will turn out differently if you compile a static binary.
Put another way, this:
Is evidently the wrong compiler for the platform.
