I have setup a Wifi Hotspot using Edimax WiFi Dongle. The Hotspot is working without the eth0 configuration.
auto lo
    iface lo inet loopback
    #wireless
    auto wlan0
    iface wlan0 inet static
    address 192.168.9.1
    netmask 255.255.255.0
    #end wireless
I can connect to SSID and ping to 192.168.9.1. Its working well. I am using Static LAN cable connection when not using the WiFi hotspot.So I changed my configuration to
auto lo
#wired
auto eth0
iface eth0 inet static
address 192.168.9.104
gateway 0.0.0.0
#end wired
#wireless
auto wlan0
address 192.168.9.1
#end wireless
Now my hotspot is not working. I can connect to SSID but unable to ping to the IP 192.168.9.1. How I can keep the static IP configuration for LAN and hotspot in the configuration.
Following is the list configuration I done in my system My dhcpd.cof contain
# Sample configuration file for ISC dhcpd for Debian
# The ddns-updates-style parameter controls whether or not the server will
# attempt to do a DNS update when a lease is confirmed. We default to the
# behavior of the version 2 packages ('none', since DHCP v2 didn't
# have support for DDNS.)
ddns-update-style none;
# option definitions common to all supported networks...
option domain-name "example.org";
option domain-name-servers ns1.example.org, ns2.example.org;
default-lease-time 600;
max-lease-time 7200;
# If this DHCP server is the official DHCP server for the local
# network, the authoritative directive should be uncommented.
#authoritative;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
log-facility local7;
# No service will be given on this subnet, but declaring it helps the
# DHCP server to understand the network topology.
#subnet 10.152.187.0 netmask 255.255.255.0 {
# This is a very basic subnet declaration.
#subnet 192.168.9.1 netmask 255.255.255.0 {
#  range 192.168.9.201 192.168.9.250;
#  option routers 192.168.9.104;
 # option broadcast-address 192.168.9.255;
subnet 192.168.9.0 netmask 255.255.255.0 {
  range 192.168.9.100 192.168.9.200;
  option domain-name "MyWifi";
# A slightly different configuration for an internal subnet.
#subnet 10.5.5.0 netmask 255.255.255.224 {
#  range 10.5.5.26 10.5.5.30;
#  option domain-name-servers ns1.internal.example.org;
#  option domain-name "internal.example.org";
#  option routers 10.5.5.1;
#  option broadcast-address 10.5.5.31;
#  default-lease-time 600;
#  max-lease-time 7200;
# Hosts which require special configuration options can be listed in
# host statements.   If no address is specified, the address will be
# allocated dynamically (if possible), but the host-specific information
# will still come from the host declaration.
#host passacaglia {
#  hardware ethernet 0:0:c0:5d:bd:95;
#  filename "vmunix.passacaglia";
#  server-name "toccata.fugue.com";
# Fixed IP addresses can also be specified for hosts.   These addresses
# should not also be listed as being available for dynamic assignment.
# Hosts for which fixed IP addresses have been specified can boot using
# BOOTP or DHCP.   Hosts for which no fixed address is specified can only
# be booted with DHCP, unless there is an address range on the subnet
# to which a BOOTP client is connected which has the dynamic-bootp flag
# set.
#host fantasia {
#  hardware ethernet 08:00:07:26:c0:a5;
#  fixed-address fantasia.fugue.com;
# You can declare a class of clients and then do address allocation
# based on that.   The example below shows a case where all clients
# in a certain class get addresses on the 10.17.224/24 subnet, and all
# other clients get addresses on the 10.0.29/24 subnet.
#class "foo" {
#  match if substring (option vendor-class-identifier, 0, 4) = "SUNW";
#shared-network 224-29 {
#  subnet 10.17.224.0 netmask 255.255.255.0 {
#    option routers rtr-224.example.org;
#  subnet 10.0.29.0 netmask 255.255.255.0 {
#    option routers rtr-29.example.org;
#  pool {
#    allow members of "foo";
#    range 10.17.224.10 10.17.224.250;
#  pool {
#    deny members of "foo";
#    range 10.0.29.10 10.0.29.230;
hostapd contain
# Defaults for hostapd initscript
# See /usr/share/doc/hostapd/README.Debian for information about alternative
# methods of managing hostapd.
# Uncomment and set DAEMON_CONF to the absolute path of a hostapd configuration
# file and hostapd will be started during system boot. An example configuration
# file can be found at /usr/share/doc/hostapd/examples/hostapd.conf.gz
DAEMON_CONF="/etc/hostapd/hostapd.conf"
# Additional daemon options to be appended to hostapd command:-
#   -d   show more debug messages (-dd for even more)
#   -K   include key data in debug messages
#   -t   include timestamps in some debug messages
# Note that -B (daemon mode) and -P (pidfile) options are automatically
# configured by the init.d script and must not be added to DAEMON_OPTS.
#DAEMON_OPTS=""
hostapd.conf contains
interface=wlan0
driver=rtl871xdrv
bridge=br0
ssid=MyWifi 4600/1500
channel=1
wmm_enabled=0
wpa=1
wpa_passphrase=secretpass
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=0
Arun Kumar K S
  • 303
