I would like to use the i2c_gpio software i2c kernel module because the broadcom hardware i2c does not support I2C_M_NOSTART. How do I do this?
I think that in order to do it I need to take the device tree config for i2c_gpio and turn it into a device tree fragment, then compile and load it. But I don't know how to rewrite the config as a fragment. Perhaps there is another, easier way.
Alistair Buxton
  • 804
As of June 2016 Raspbian already has the necessary modifications. You only need to enable the overlay in config.txt (step 6 onwards).
I finally got this working as follows:
  1. Rebuild the kernel with i2c_gpio module. You must edit the bcm2708_defconfig or bcmrpi_defconfig and add the line CONFIG_I2C_GPIO=m before running the make defconfig.
  2. Install kernel and modules using mkknlimg for device tree support as described in the kernel building docs.
  3. Convert the example i2c_gpio config to a device tree fragment as follows:
    // Overlay for i2c_gpio bitbanging host bus.
    /dts-v1/;
    /plugin/;
            compatible = "brcm,bcm2708";
            fragment@0 {
                    target-path = "/";
                    __overlay__ {
                            i2c_gpio: i2c@0 {
                                    compatible = "i2c-gpio";
                                    gpios = <&gpio 23 0 /* sda */
                                             &gpio 24 0 /* scl */
                                    i2c-gpio,delay-us = <2>; /* ~100 kHz */
                                    #address-cells = <1>;
                                    #size-cells = <0>;
            __overrides__ {
                    i2c_gpio_sda = <&i2c_gpio>,"gpios:4";
                    i2c_gpio_scl = <&i2c_gpio>,"gpios:16";
                    i2c_gpio_delay_us = <&i2c_gpio>,"i2c-gpio,delay-us:0";
    • This will default to using gpio 23 and 24 for software i2c.
    • delay-us should be 2 for 100kHz operation.
    • The following lines should be removed because they will prevent the driver from working on Raspberry Pi: i2c-gpio,sda-open-drain; i2c-gpio,scl-open-drain;
  4. Build the device tree blob with dtc -@ -I dts -O dtb -o i2c-gpio.dtb i2c-gpio.dts
  5. Copy the blob to /boot/overlays/
  6. Add a line in /boot/config.txt dtoverlay=i2c-gpio
    If you want to use different pins, put dtoverlay=i2c-gpio,i2c_gpio_sda=<pin>,i2c_gpio_scl=<pin> instead. You can also change the rate with i2c_gpio_delay_us=<usecs>.
  7. Reboot.
  8. modprobe i2c-dev and you now should have /dev/i2c-3 in addition to any others you previously configured.
Alistair Buxton
  • 804
