I have a 3.5" display. It works fine, but since the display is small, most of the windows cannot appear on the screen because they are larger.
The current resolution is fine (it's default), but is it possible to force it to display all the elements on the screen a little bit smaller? That would help to get some more space.
How can I do that?
Ionică Bizău
  • 723
  • 33
5 Answers5
It is window manger's + application issue. Application authors may have set default window's sizes too big.
You may check your window manager's documentation to find options to resize windows. Or move to tiling window managers to have windows always fit your screen.
kassak
  • 158
As mentioned by kassak, this issue is down to the window manager and the individual applications. There's not much we can do for the application outside of getting the source code and modifying them to work at smaller sizes.
We can deal with the window manager though, what you need is either a tiling window manager, or one that can control the DPI or scaling. I have no experience with the former, but for the latter I recommend xfce4, it's very light weight, so the Pi will handle it fine, and it has a settings manager window which wraps around all of the various settings editors, this means that if the setting you want is off screen you can scroll to access it, even if the developer set a fixed window size.
Instructions for how to install xfce4 can be found quite easily, but I won't link so the links don't go stale.
To change the DPI/scaling will depend on the window manager you choose. For xfce4 go:
  • Applications menu (should be top left by default)
  • Settings
  • Settings Editor
  • Appearance
  • Fonts Tab
  • Tick "Custom DPI Setting"
  • Change the number to the right to what feels best to you
There are some DPI related settings that you can try from this post:
https://stackoverflow.com/questions/49688781/dpi-scaling-on-nixos-with-lightdm-xmonad
I haven't tested them, but you can try one at a time to see which help. Bear in mind you may need to restart the X-Windows to get the settings to take effect.
Copied here for ease of reference:
✓ services.xserver.dpi = 180; (sets xserver flag)
✓ .Xresources settings
Xft.dpi: 180
Xft.autohint: 0
Xft.lcdfilter:  lcddefault
Xft.hintstyle:  hintfull
Xft.hinting: 1
Xft.antialias: 1
Xft.rgba: rgb
✓ export GDK_SCALE=2
✓ export GDK_DPI_SCALE=0.5
✓ export XCURSOR_SIZE=32
✓ export QT_AUTO_SCREEN_SCALE_FACTOR=1
For Pi's running bookworm with Wayland labwc, this can be accomplished pretty easily.
Modify ~/.config/labwc/autostart and add the following line:
wlr-randr --output SPI-1 --scale 0.5
Replacing the output and scale factor as appropriate. You can run wlr-randr with no arguments to see what outputs are available. In my case
I'm using a 2.0" SPI dispay controlled using the mipi-dbi-spi overlay driver, so the display shows up as SPI-1, and a scale factor of 0.5 makes the desktop appear as if its a 640x480 display even though the native resolution is 320x240. Not the greatest scaling in terms of picture quality, but does the job.
I have had this problem to. For most windows, you can simply drag it into you see the maximize button and click that, then it fits the screen. For ones without a maximize button, such as Python games, your out of luck. :-(
Triforcey
  • 141
