I have a Raspberry pi B, using Debian, just rigged up with a 3.5 inch TFT-LCD monitor via VGA. The text size in command line mode is too small to read, so I would like to increase its size, and one method says "edit /boot/config.txt". However the command ls /boot shows no config.txt -- the only .txt file is cmdline.txt.
Another method ref: http://www.raspberrypi-spy.co.uk/2012/11/cheap-miniature-lcd-screen which says use sudo dpkg-reconfigure console-setup doesn't seem to make any difference.
Have I done something wrong? I'd appreciate any help in progressing forward from here.
