I am working on a project similar to the one at http://www.instructables.com/id/Raspberry-Pi-Wall-Mounted-Google-Calendar/?ALLSTEPS
Similarly, I need my pi to stay on constantly. I have the regular Raspbian OS installed and I am using Iceweasel browser to run a web application all day.
I have tried every single one of these suggestions from this link http://www.bitpi.co/2015/02/14/prevent-raspberry-pi-from-sleeping/
Yet the pi fails to stay on longer than 10 minutes. Any help would be greatly appreciated.
Javed Ali
  • 123
I don't know why it's not working since the last option mentioned in that post (lightdm configuration - Xsession blanking) worked pretty good for me.
Here is the easiest way for you.
Install xscreensaver by "sudo apt-get install xscreensaver"
Once installed, go to Rpi's desktop "Menu" (left top corner) [I'm assuming that you're running a raspbian?]
Go to preference ---> screensaver.
You will see a screen saver main menu. In mode : section, select "disable screensaver" and close.
Reboot Rpi. It should work now.
Also have a look at links below:
Disable screen blanking in X-Windows on Raspbian
How do I prevent the screen from going blank?
Hope it helps.
dhruvvyas90
  • 2,883
  • 33
