I have a large monitor which I'd like to use with the Raspberry Pi 2 Model B. The monitor is an LG 21:9 ultrawide so a little unusual.
I'm running Ubuntu Mate and the resolution is defaulting to 1824 x 984.
I realise this is optimistic but is there a driver which can handle larger screen sizes or is the onboard graphics just not up to it?
codecowboy
  • 201
The maximum resolution the rPi can output (through its VideoCore IV chip) is 1920x1080. This is a 16:9 aspect ratio. This link on raspberrypi.org shows that it is possible to get a 21:9 aspect ratio working - There are people that report being able to run at 2560x1080 on OpenELEC.
You will need to play with the HDMI timings in config.txt. Executing
tvservice -m DMT
will list the necessary parameters for your monitor.
The format of the new lines you need to add to config.txt is:
hdmi_cvt=<width> <height> <framerate> <aspect> <margins> <interlace> <rb>
width        width in pixels
height       height in pixels
framerate    framerate in Hz
aspect       aspect ratio 1=4:3, 2=14:9, 3=16:9, 4=5:4, 5=16:10, 6=15:9
margins      0=margins disabled, 1=margins enabled
interlace    0=progressive, 1=interlaced
rb           0=normal, 1=reduced blanking
Phil B.
  • 5,053
  • 30
Here's what worked for me in config.txt:
    hdmi_ignore_cec_init=1
hdmi_drive=2
disable_overscan=1
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=87
hdmi_timings=2560 1 64 64 96 1080 1 3 10 31 0 0 1 60 0 185580000 8
config_hdmi_boost=4
max_framebuffer_width=2560
max_framebuffer_height=1280
framebuffer_height=1080
gpu_mem=128
arm_freq=900
gpu_freq=275
sdram_freq=500
hdmi_pixel_freq_limit=400000000
avoid_pwm_pll=1
output of tvservice -s:
state 0x12001a [HDMI DMT (87) RGB full unknown AR x1], 2560x1080 @ 60.00Hz, progressive
codecowboy
  • 201
