19
I have Model B and connected via Ethernet and running Raspbmc.
It's taking new IP address whenever I restart it, of course may be because of DHCP, but I want to configure this Raspberry Pi with a static IP address, so that I can use my XBMC remote.
Alex Chamberlain
  • 15,638
garikapati
  • 315
Per the instructions found here:
  1. In XBMC, go to Programs → Raspbmc settings → Wired network configuration.
  2. Uncheck the Automatic DHCP option.
  3. Provide a static IP address. Make sure the IP address is far away from the IP addresses typically assigned by the router to the networked devices at home. For example, if a router assigns addresses starting from 192.168.0.10, then pick a static IP like 192.168.0.50
  4. Scroll down and check the Update Now option. Raspbmc will take a few seconds to apply the new configuration.
  5. Make sure you can ping the static IP address you assigned. Voila, your Raspbmc now has a fixed IP address!
Steve Robillard
  • 34,988
  • 106
  • 110
14
A solution would be to configure a DHCP static lease, if your router allows it. I like this solution because:
  • I can set all of my connected devices' IP address and DNS configuration in a unique place.
  • The Raspberry Pi won't get a taken IP address
  • I can bring my Raspberry Pi to a friend's place without reconfigure it
  • I can have multiple OS on the Raspberry Pi without configure them
  • I can reinstall the OS without reconfigure it
To configure a DHCP static lease:
  1. In a terminal on the Raspi, run the ifconfig command to know its MAC address (HWaddr XX:XX:XX:XX:XX:XX).
  2. Open your favorite browser and enter your router's IP address. Probably 192.168.0.1 or 192.168.1.1.
  3. Look for the DHCP static lease option. In the example here, the "DCHP Reservation" button.
  4. Enter the MAC address you picked up in the first step and associate it with the IP address you want to. Click here to see an example of the web interface.
  5. Restart the RPi to make it get the IP address you just set up.
Morgan Courbet
  • 3,703
  • 38
For those of you (like me) who prefer to do things the manual way, then you can edit the interface file at /etc/network/interfaces:
# DHCP
# iface eth0 inet dhcp
# Static
iface eth0 inet static
address xxx.xxx.xxx.xxx
netmask xxx.xxx.xxx.xxx
gateway xxx.xxx.xxx.xxx
You will then need to restart the network service...
Andrew
  • 216
