I've been wondering how I could reset my raspberry pi 2 to its stock clock after I used the raspi-config utils. The only options I had were primarily for the first Raspberry. There's no "default" value for the Pi2.
Something like this:
Chose overclock preset
None 700MHz ARM, 250MHz core, 400MHz SDRAM, 0 overvolt
Modest 800MHz ARM, 250MHz core, 400MHz SDRAM, 0 overvolt
Medium 900MHz ARM, 250MHz core, 450MHz SDRAM, 2 overvolt
High 950MHz ARM, 250MHz core, 450MHz SDRAM, 6 overvolt
Turbo 1000MHz ARM, 500MHz core, 600MHz SDRAM, 6 overvolt
Pi2 1000MHz ARM, 500MHz core, 500MHz SDRAM, 2 overvolt
As you can see, it's possible to overclock the default 900Mhz from the raspberry pi 2, but there's no solution for going back to stock configuration using the raspi-config tool. So how on Earth are we supposed to rollback after an overclock?
