Running headless with: Linux weatherpi 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux
I am using the raspberry camera module.
I can stream video, I've tried both motion (not mmal, std motion), which works "out of the box" and uv4l-webrtc (Thank you ppumkin), which also works "out of the box".
However, both of these solutions seem to crash my P2. Mostly with bright light, although that's just a guess based on un-scientific observation. It runs anywhere from 30 secs to 20 hours without fail. Then it causes a reboot. Doesn't seem to matter if I'm streaming at the time or not. I've tried running motion with -d 9 but that doesn't give me anything useful. Below is the syslog from a recent failure. Seems to be a network issue but that doesn't make sense because it only happens if motion or uv4l-webrtc are running, regardless of if they are streaming at the time. Using USB wireless dongle (WIPI). Wondering if there might be an issue in conflict between the bus taking the camera images and the USB bus??
Note: Power supply is 5V 2amp and it's never had an issue before but I'm open to trying another if someone suggests it. I've ordered another camera module to test but it's still on the way. Any suggestions on what the issue is or how to get more info to debug would be helpful.
May 12 10:14:37 weatherpi kernel: [63914.576521] wlan0: AP 64:66:b3:90:73:36 changed bandwidth, new config is 2462 MHz, width 1 (2462/0 MHz)
May 12 10:14:38 weatherpi kernel: [63915.600522] wlan0: AP 64:66:b3:90:73:36 changed bandwidth, new config is 2462 MHz, width 2 (2452/0 MHz)
May 12 10:17:01 weatherpi /USR/SBIN/CRON[3584]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
May 12 10:18:53 weatherpi kernel: [64170.913294] fuse init (API version 7.23)
May 12 10:23:56 weatherpi kernel: [64473.394074] ieee80211 phy0: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -71
May 12 10:23:56 weatherpi kernel: [64473.394292] ieee80211 phy0: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -71
May 12 10:23:56 weatherpi kernel: [64473.394536] ieee80211 phy0: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -71
May 12 10:23:56 weatherpi kernel: [64473.394844] ieee80211 phy0: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -71
May 12 10:23:56 weatherpi kernel: [64473.395344] ERROR::dwc_otg_hcd_urb_enqueue:505: Not connected
May 12 10:23:56 weatherpi kernel: [64473.396051] ieee80211 phy0: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -108
May 12 10:23:56 weatherpi kernel: [64473.396086] ERROR::dwc_otg_hcd_urb_enqueue:505: Not connected
May 12 10:23:56 weatherpi avahi-daemon[2359]: Withdrawing workstation service for eth0.
May 12 10:23:56 weatherpi kernel: [64473.411286] usb 1-1: USB disconnect, device number 2
May 12 10:23:56 weatherpi kernel: [64473.411331] usb 1-1.1: USB disconnect, device number 3
May 12 10:23:56 weatherpi kernel: [64473.411780] smsc95xx 1-1.1:1.0 eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
May 12 10:23:56 weatherpi kernel: [64473.411891] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
May 12 10:23:56 weatherpi kernel: [64473.468026] usb 1-1.4: USB disconnect, device number 4
May 12 10:23:56 weatherpi wpa_supplicant[1657]: wlan0: CTRL-EVENT-DISCONNECTED bssid=64:66:b3:90:73:36 reason=3
May 12 10:23:56 weatherpi avahi-daemon[2359]: Interface wlan0.IPv4 no longer relevant for mDNS.
May 12 10:23:56 weatherpi avahi-daemon[2359]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.221.
May 12 10:23:56 weatherpi kernel: [64473.581055] wlan0: deauthenticating from 64:66:b3:90:73:36 by local choice (Reason: 3=DEAUTH_LEAVING)
May 12 10:23:56 weatherpi avahi-daemon[2359]: IP_DROP_MEMBERSHIP failed: No such device
May 12 10:23:56 weatherpi avahi-daemon[2359]: Withdrawing address record for 192.168.0.221 on wlan0.
May 12 10:23:56 weatherpi avahi-daemon[2359]: Withdrawing workstation service for wlan0.
May 12 10:23:56 weatherpi kernel: [64473.646179] cfg80211: Calling CRDA for country: US
May 12 10:23:56 weatherpi ifplugd(eth0)[1682]: Exiting.
May 12 10:23:56 weatherpi kernel: [64473.941110] Indeed it is in host mode hprt0 = 00021501
May 12 10:23:56 weatherpi ifplugd(wlan0)[1591]: Link beat lost.
May 12 10:23:56 weatherpi wpa_supplicant[1657]: wlan0: Failed to initiate AP scan
May 12 10:23:56 weatherpi ifplugd(wlan0)[1591]: Exiting.
May 12 10:23:56 weatherpi kernel: [64474.153835] usb 1-1: new high-speed USB device number 5 using dwc_otg
May 12 10:23:56 weatherpi kernel: [64474.154479] Indeed it is in host mode hprt0 = 00001101
May 12 10:23:57 weatherpi kernel: [64474.451411] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
May 12 10:23:57 weatherpi kernel: [64474.451443] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
May 12 10:23:57 weatherpi kernel: [64474.452544] hub 1-1:1.0: USB hub found
May 12 10:23:57 weatherpi kernel: [64474.452717] hub 1-1:1.0: 5 ports detected
May 12 10:23:57 weatherpi kernel: [64474.731412] usb 1-1.1: new high-speed USB device number 6 using dwc_otgMay 12 10:23:57 weatherpi kernel: [64474.832250] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00May 12 10:23:57 weatherpi kernel: [64474.832284] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
May 12 10:23:57 weatherpi kernel: [64474.836023] smsc95xx v1.0.4
May 12 10:23:57 weatherpi kernel: [64474.900007] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethern
et, b8:27:eb:be:c4:df
May 12 10:23:57 weatherpi kernel: [64474.991254] usb 1-1.4: new high-speed USB device number 7 using dwc_otg
May 12 10:23:57 weatherpi ifplugd(eth0)[4667]: ifplugd 0.28 initializing.
May 12 10:23:57 weatherpi ifplugd(eth0)[4667]: Using interface eth0/B8:27:EB:BE:C4:DF with driver (version: 22-Aug-2005)
May 12 10:23:57 weatherpi ifplugd(eth0)[4667]: Using detection mode: SIOCETHTOOL
May 12 10:23:57 weatherpi ifplugd(eth0)[4667]: Initialization complete, link beat not detected.
May 12 10:23:57 weatherpi kernel: [64475.107012] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
May 12 10:23:57 weatherpi kernel: [64475.112358] usb 1-1.4: New USB device found, idVendor=148f, idProduct=5370
May 12 10:23:57 weatherpi kernel: [64475.112393] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 12 10:23:57 weatherpi kernel: [64475.112411] usb 1-1.4: Product: 802.11 n WLAN
May 12 10:23:57 weatherpi kernel: [64475.112427] usb 1-1.4: Manufacturer: Ralink
May 12 10:23:57 weatherpi kernel: [64475.112443] usb 1-1.4: SerialNumber: 1.0
May 12 10:23:58 weatherpi kernel: [64475.191182] usb 1-1.4: reset high-speed USB device number 7 using dwc_otg
May 12 10:23:58 weatherpi kernel: [64475.302406] ieee80211 phy1: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
May 12 10:23:58 weatherpi kernel: [64475.325579] ieee80211 phy1: rt2x00_set_rf: Info - RF chipset 5370 detected
May 12 10:23:58 weatherpi kernel: [64475.326612] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
May 12 10:23:58 weatherpi kernel: [64475.328672] ieee80211 phy1: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
May 12 10:23:58 weatherpi kernel: [64475.329122] ieee80211 phy1: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
May 12 10:23:58 weatherpi ifplugd(wlan0)[4688]: ifplugd 0.28 initializing.
May 12 10:23:58 weatherpi ifplugd(wlan0)[4688]: Using interface wlan0/00:0F:13:28:12:B8 with driver (version: 3.18.11-v7+)
May 12 10:23:58 weatherpi ifplugd(wlan0)[4688]: Using detection mode: SIOCETHTOOL
May 12 10:23:58 weatherpi ifplugd(wlan0)[4688]: Initialization complete, link beat not detected.
May 12 10:23:58 weatherpi wpa_supplicant[4702]: ctrl_iface exists and seems to be in use - cannot override it
May 12 10:23:58 weatherpi wpa_supplicant[4702]: Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore
May 12 10:23:58 weatherpi wpa_supplicant[4702]: Failed to initialize control interface '/var/run/wpa_supplicant'.#012You may have another wpa_supplicant process already running or the file was#012left by an unclean termination of wpa_supplicant in which case you will need#012to manually remove this file before starting wpa_supplicant again.
May 12 10:23:58 weatherpi wpa_supplicant[1657]: wlan0: CTRL-EVENT-TERMINATING - signal 15 received
May 12 10:23:59 weatherpi avahi-daemon[2359]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.221.
May 12 10:23:59 weatherpi avahi-daemon[2359]: New relevant interface wlan0.IPv4 for mDNS.
May 12 10:23:59 weatherpi avahi-daemon[2359]: Registering new address record for 192.168.0.221 on wlan0.IPv4.
May 12 10:24:06 weatherpi watchdog[2423]: device wlan0 did not receive anything since last check
May 12 10:24:06 weatherpi watchdog[2423]: /usr/lib/sendmail does not exist or is not executable (errno = 2)
May 12 10:24:06 weatherpi watchdog[2423]: shutting down the system because of error 101
May 12 10:24:16 weatherpi kernel: [64493.332189] wdt: WDT device closed unexpectedly. WDT will not stop!
May 12 10:24:16 weatherpi ifplugd(wlan0)[4688]: Exiting.
May 12 10:17:11 weatherpi kernel: imklog 5.8.11, log source = /proc/kmsg started.
May 12 10:17:11 weatherpi rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="2090" x-info="http://www.rsyslog.com"] start
May 12 10:17:11 weatherpi kernel: [ 0.000000] Booting Linux on physical CPU 0xf00
