I have a Rapberry Pi (model B), wired connected on network.
I want to stream using raspistill and save loop jpeg picture into a fifo file. In the other side I want to read this fifo file with VLC, and display it.
I tried somthing like this:
mkfifo fifo
wget -O /home/pi/fifo http://192.168.1.27:8554 & omxplayer -r /home/pi/fifo
and this:
cvlc --rc-host 192.168.1.27:8554 /home/pi/fifo -d
to read localy the stream (networkless) I tryed:
cvlc < fifo
(rpi and PC are both on linux)
(I already stream without fifo on VLC player)
Any ideas?
Ghanima
  • 15,958
  • 65
Jérémy
  • 121
fifos are not for saving or reading more than once. You may find tee better suited to your goals.
Untested guess at what you want(split a network stream):
mkfifo myfifo1 myfifo2 && curl -s http://192.168.1.27:8554 | tee myfifo1 > myfifo2;
Other guess at what you want(display and save on rpi):
raspistill --fullpreview --output - >> jpgs.dat
or using more than one file in a loop
or using raspivid
raspivid -fps 2 --timeout 0 --fullscreen --output $(date +%Y%M%dT%H%m%S).h264
Note that you can set the fps on raspivid and with it's temporal compression it may be better than looping raspistill in some conditions.
user1133275
  • 2,216
