13
I've seen advice here for resizing, which is fine if you have another linux distribution to work with.
How can I do resize the partition otherwise? Are there any Windows tools for example?
Alex Chamberlain
  • 15,638
weston
  • 321
The e2fsprogs package can be installed on Windows (via cygwin) and Mac OS X (via MacPorts).
You can then use resize2fs as described in the linked wiki page.
I have not been able to resize the image on the SD card directly under Windows, however you can back up the linux partition to a file (as described in another question), run resize2fs on the file, then restore the enlarged partition from the file back to the partition on the SD card.
finnw
  • 5,790
  • 34
The easiest thing is to image the OS onto a SD card.
Then using MiniTool Partition Wizard you can very easily change the size of partitions on the SD card.
There is also an option in raspi-config that will set the OS to use the whole of the SD card, if that's what your after
Darth Vader
  • 4,218
  • 47
  • 70
