I am trying to compile a simple helloworld module on my Raspberry Pi B+ under the 3.18.7+ Kenel. I did it after THIS tutorial. When I try to build my module I have this error :
make[1]: *** /lib/modules/3.18.7+/build: No such file or directory.  Stop
When I go to my /lib/modules/3.18.7+/build directory I have the following files :
 modules.alias
 modules.builtin
 modules.dep
 modules.devname
 modules.softdep
 modules.symbols.bin
 kernel
 modules.alias.bin
 modules.builtin.bin
 modules.dep.bin
 modules.order
 modules.symbols
As you can see, there is no build directory. I made some researches on the internet so I find that I have to made a link to the kernel source tree used to build the modules, by using this command
ln -s /path/to/kernel/source  /lib/modules/3.18.7+/build
So I did so by typing the following command :
ln -s /usr/src/linux-kbuild-3.18  /lib/modules/3.18.7+/build
Even if I did that, I still got the same error that the one in the beginning. In the directory /usr/src/linux-kbuild-3.18 I have only a scripts directory containing those files :
basic             gcc-goto.sh                        kallsyms        Makefile.clean      makelst            namespace.pl     ver_linux
checkincludes.pl  gcc-version.sh                     Kbuild.include  Makefile.extrawarn  mksysmap           patch-kernel
checkstack.pl     gcc-x86_32-has-stack-protector.sh  kconfig         Makefile.host       mkuboot.sh         pnmtologo
checkversion.pl   gcc-x86_64-has-stack-protector.sh  kernel-doc      Makefile.lib        mkversion          recordmcount
conmakehash       gen_initramfs_list.sh              Lindent         Makefile.modinst    mod                recordmcount.pl
depmod.sh         genksyms                           Makefile.build  Makefile.modpost    module-common.lds  setlocalversion
If there is any solution it will be great, thanks
EngineerN
  • 81
That /usr/src/linux-kbuild-3.18 does not appear to be a kernel source directory; it is possibly some related tools provided by the distro. A kernel source tree looks like this.
Normal linux distros, including Debian, always have a source package available corresponding to their kernels. Unfortunately with Raspbian this is not the case, you must get it from github:
git clone https://github.com/raspberrypi/linux.git
Beware this is almost 2 GB of stuff. Modules must be built against exactly the same source version as the kernel. Generally this is pretty straightforward, but I am not sure if the '+' suffix sometimes used with the raspberry pi kernels has any significance in this sense. The versions are given in the commit comment on Makefile, e.g.;
> git log Makefile
commit c963de6d8caec6278c0dde76831f9fdab5bace52
Author: Sasha Levin <sasha.levin@oracle.com>
Date:   Mon Apr 20 15:48:02 2015 -0400
    Linux 3.18.12
    Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
commit f154a14e3efa547025d014d0a3f29396f03b1f74
Date:   Fri Apr 3 22:46:37 2015 -0400
    Linux 3.18.11
commit 96e199f1751e707a7a8c04d9b079f84df2e0d4ff
Date:   Mon Mar 23 21:05:12 2015 -0400
    Linux 3.18.10
3.18.7 turns out to be a17f9bf1f7cd3412b9920577a7c0ec34cb81b233, so:
> git reset --hard a17f9bf1f7cd3412b9920577a7c0ec34cb81b233
Should take you back to that. I believe in order to make this work with an external module, you first need to:
make bcmrpi_defconfig
make modules_prepare
I don't think you have to do more than that but if you do need to build the kernel itself -- which will take hours on a pi -- you might as well switch to back to the latest version:
make mrproper
git reset --hard 'HEAD@{1}'
make
make modules_install
You would then need to install the kernel:
cp arch/arm/boot/bzImage /boot/linux-3.18-12
And edit /boot/config.txt:
kernel=linux-3.18.12
So I got a solution by using ARCHLINUX instead of Raspbian. It's a great distribution. After installing it on the raspberry, you need to update tour system with pacman -Syu, after that you need to reboot your system with reboot. You write your kernel module and your Makefile. When you'll try to compile your module you will have many missing packages which didn't get installed while updating the system. You will need to install them pacman -S base-devel and that's it ! Thanks for your help guys !!
EngineerN
  • 81
You can install the source corresponding to the current kernel using rpi-source
Using a raspbian wheezy you will need the following steps:
sudo wget https://raw.githubusercontent.com/notro/rpi-source/master/rpi-source -O /usr/bin/rpi-source && sudo chmod +x /usr/bin/rpi-source && /usr/bin/rpi-source -q --tag-update
echo deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free | sudo tee /etc/apt/sources.list.d/jessie.list
sudo apt-get update
sudo apt-get install -y gcc-4.8 g++-4.8
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.6 20
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.8 50
sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-4.6 20
sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-4.8 50
sudo rpi-source
I guess with a jessie distribution it is simpler (gcc upgrade should not be needed), but last time I tried to run a dist-upgrade the system was not booting anymore.
mpromonet
  • 1,124
  • 38
