I am trying to build Native WebRTC on Pi2 using the following commands
sudo apt-get install git
sudo git clone https://chromium.googlesource.com/chromium/tools/depot_tools.git /opt/depot_tools
echo "export PATH=\$PATH:/opt/depot_tools" | sudo tee /etc/profile.d/depot_tools.sh
source /etc/profile
mkdir webrtc
cd webrtc
GYP_DEFINES="clang=0" fetch --no-history webrtc
This fails ending with :
________ running '/usr/bin/python src/tools/clang/scripts/update.py --if-needed' in '/home/pi/webrtc/src/chromium'
Error: Command /usr/bin/python src/tools/clang/scripts/update.py --if-needed returned non-zero exit status 1 in /home/pi/webrtc/src/chromium
File "src/tools/clang/scripts/update.py", line 324, in <module>
sys.exit(main())
File "src/tools/clang/scripts/update.py", line 304, in main
stderr=os.fdopen(os.dup(sys.stdin.fileno())))
OSError: [Errno 22] Invalid argument
Hook '/usr/bin/python -u src/sync_chromium.py --target-revision d5098d02757b36232af2a50c2bcaa9dc36e70017' took 4732.59 secs
Running: gclient config --spec 'solutions = [
"managed": False,
"name": "src",
"url": "https://chromium.googlesource.com/external/webrtc.git",
"custom_deps": {},
"deps_file": "DEPS",
"safesync_url": "",
Running: gclient sync --no-history --with_branch_heads
File "/opt/depot_tools/fetch.py", line 335, in <module>
sys.exit(main())
File "/opt/depot_tools/fetch.py", line 330, in main
return run(options, spec, root)
File "/opt/depot_tools/fetch.py", line 324, in run
return checkout.init()
File "/opt/depot_tools/fetch.py", line 136, in init
self.run_gclient(*sync_cmd)
File "/opt/depot_tools/fetch.py", line 76, in run_gclient
return self.run(cmd_prefix + cmd, **kwargs)
File "/opt/depot_tools/fetch.py", line 66, in run
return subprocess.check_call(cmd, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 511, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '('gclient', 'sync', '--no-history', '--with_branch_heads')' returned non-zero exit status 2
I tried with many revision, with one gclient revinfo -a says:
src: https://chromium.googlesource.com/external/webrtc.git@bd67f66ebd1ee5a4605ca14b230ec5ee8bf6407e
src/third_party/gflags/src: https://chromium.googlesource.com/external/gflags/src@e7390f9185c75f8d902c05ed7d20bb94eb914d0c
src/third_party/junit: https://chromium.googlesource.com/external/webrtc/deps/third_party/junit@f35596b476aa6e62fd3b3857b9942ddcd13ce35e
As uv4l-webrtc use it, it should be possible to build it, but how ?
