I just buy a Raspberry Pi 2, this is my first one! I love it!
I install Ubuntu Snappy Core, plug the monitor, keyboard, internet cable then install program and have fun.
I check that sshd is running, then I poweroff, plug off monitor, keyboard, power supply and reboot (with the internet cable).
In my router, I can check what devices connected to internet, and I don't see My RPi 2 on the list, only my laptop.
So my question is Will RPi 2 with Ubuntu Snappy Core boot or connect to interner without monitor and keyboard?
Asked
Active
Viewed 1,271 times
nvcnvn
- 103
- 4
Yes, Snappy Ubuntu Core will run headless from the very first boot. It uses DHCP to obtain network configuration information from a DHCP server (such as a router or gateway) on the local network. It also runs sshd from first boot, so that you can ssh into it from another machine in order to be able to use it. Most home routers will have a web interface that will allow you to see the name/address that has been assigned to your RPi so that you know what to ssh in to. Failing that, you can use "nmap" or similar to find it.
Darren Wilkinson
- 2,922
- 4
- 28
- 27
