10
When I run hcitool scan the shell shows Scanning... for ~10 sec but doesn't show any results.
Same for sudo hcitool scan
(I have an Android phone and a PC nearby with bluetooth activated and set to visible)
(It did work the first time; I didn't change anything since then)
System Specs
Bluetooth adapter is a Hama 00049229 (Manual)
Chipset:
Bus 001 Device 005: ID 0a5c:2121 Broadcom Corp. BCM2210 Bluetooth
hciconfig shows:
hci0:   Type: BR/EDR  Bus: USB
        BD Address: 00:0D:18:01:5A:B3  ACL MTU: 1017:8  SCO MTU: 64:0
        UP RUNNING PSCAN
        RX bytes:849 acl:0 sco:0 events:39 errors:0
        TX bytes:420 acl:0 sco:0 commands:35 errors:0
(As commented by Tim Holt)
hcitool dev shows:
Devices:
    hci0    00:0D:18:01:5A:B3
(Also as commented by Tim Holt)
I ran hcidump --raw and the scan tool found all nearby bluetooth devices. Here is the dump (I scanned twice):
HCI sniffer - Bluetooth packet analyzer ver 2.4
device: hci0 snap_len: 1028 filter: 0xffffffff
< 01 01 04 05 33 8B 9E 08 00
> 04 0F 04 00 01 01 04
> 04 22 0F 01 65 FF 3D 83 15 00 01 00 04 01 12 BD 6B C9
> 04 22 0F 01 65 FF 3D 83 15 00 01 00 04 01 12 BD 6B C8
> 04 22 0F 01 65 FF 3D 83 15 00 01 00 04 01 12 BD 6B CA
> 04 22 0F 01 65 FF 3D 83 15 00 01 00 04 01 12 BD 6B C7
> 04 22 0F 01 65 FF 3D 83 15 00 01 00 04 01 12 BD 6B C5
> 04 01 01 00
< 01 19 04 0A 65 FF 3D 83 15 00 01 00 BD EB
> 04 0F 04 00 01 19 04
> 04 07 FF 00 65 FF 3D 83 15 00 4D 69 63 68 69 73 2D 50 43 00
  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
And then, everything went back to normal (broken) again and hcidump --raw showed:
> 04 01 01 00
dmesg | grep -i bluetooth shows:
[    5.875950] Bluetooth: Core ver 2.19
[    6.000541] Bluetooth: HCI device and connection manager initialized
[    6.202400] Bluetooth: HCI socket layer initialized
[    6.209332] Bluetooth: L2CAP socket layer initialized
[    6.586384] Bluetooth: SCO socket layer initialized
[   29.059873] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   29.059914] Bluetooth: BNEP filters: protocol multicast
[   29.059972] Bluetooth: BNEP socket layer initialized
[   29.132785] Bluetooth: RFCOMM TTY layer initialized
[   29.132869] Bluetooth: RFCOMM socket layer initialized
[   29.132930] Bluetooth: RFCOMM ver 1.11
Raspberry Pi is model B Rev2
Installed packages:
  • bluetooth
  • bluez-utils
  • bluez-compat
  • bluez-hcidump
gizmo
  • 109
Try running the following:
sudo bluetoothctl
agent on
default-agent
scan on
Type scan off to stop scanning.
Elliptica
  • 169
This is an ancient but wrong thread. Unfortunately pretty typical- instead of explaining "hcitools" it switches to another commands.... It looks as hcitool {options} are not My best guess
q5@q5-desktop:~$ hcitool dev Devices: hci1 00:50:B6:80:4D:5D
This should work
hcitool -i hciX scan --flush
BUT it is failing
hcitool -i hci1 scan --flush Scanning ... Inquiry failed: Invalid argument
PS hcitool --help has no "argument" - what is this missing argument ? ?
Jan Hus
  • 651
  • 22
From an anonymous edit:
Whenever you see something like:
[bluetooth]# scan on
Failed to start discovery: org.bluez.Error.NotReady
Power the chip on explicitly, type:
[bluetooth]# power on
[CHG] Controller 00:1A:7D:DA:71:08 Class: 0x500000
Changing power on succeeded
[CHG] Controller 00:1A:7D:DA:71:08 Powered: yes
Greenonline
  • 2,969
  • 38
