I am trying to install Upstart, this is what I do
sudo apt-get install upstart Reading package lists... Done Building dependency tree
Reading state information... Done The following extra packages will be installed: init libjson-c2 libudev1 sysvinit Suggested packages: graphviz upstart-monitor The following NEW packages will be installed: init libjson-c2 libudev1 upstart The following packages will be upgraded: sysvinit 1 upgraded, 4 newly installed, 0 to remove and 295 not upgraded. Need to get 0 B/689 kB of archives. After this operation, 1898 kB of additional disk space will be used. Do you want to continue [Y/n]?
but then I got this error
upstart:armhf conflicts with sysvinit:armhf
How to solve this?
Edit: more complete output
Debian have decided to use systemd rather than Upstart.
Raspbian is mainly a recompilation of Debian to work on the Pi and uses systemd with jessie.
I suppose you could try removing systemd.
Why do you want to use Upstart? Which feature do you need?
I get a different message if I want to install Upstart.
Suggested packages:
  graphviz
The following packages will be REMOVED:
  sysvinit
  upstart
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
  sysvinit
0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
Need to get 502 kB of archives.
After this operation, 940 kB of additional disk space will be used.
You are about to do something potentially harmful.
To continue type in the phrase 'Yes, do as I say!'
joan
  • 71,852
  • 76
  • 108
