I am new to Raspberry Pi. My basic requirement is to get the live stream from 3 cameras using a Raspberry Pi B. It can be at a low fps. I'm planning to use 2 USB cameras and one RPi Camera Module simultaneously. (Cause using 3 USB Cams using a Hub would consume too much Memory and Power, right?)
So, By far, I've managed to:
1) Interface a USB camera and run Motion service and view the live stream on a remote system on the same network. (using this tutorial and other help I found online)
2) Interface the RPi Camera Module using Mjpeg_Streamer. (using this tutorial and other links)
Now, I want to know if I can connect the RPi camera module and the USB webcam, and an additional unit of the USB webcam, and get live stream from all three at 3 different ports. (8081, 8082, 8083, say)
I did some reading on Motion - MMAL camera but it will interface only the RPi module and not the USB Cameras because of the large inconsistency in the conf file. I also saw something about UV4L somewhere but couldn't really understand much. Basically I want all three to be functional. Any suggestions?
UPDATE:
The problem with 3 cameras is that, the first two were USB, but the third is a RPi Camera Module, and I'm unable to run motion for that camera. Basically I need to know what additional modules do I need to install and what sort of edits do I need to make in the conf file to be able to run Motion for the conventional RPi Camera Module.
Aldo
  • 121
