Can you use a micro SD card from raspberry pi B+ on the raspberry pi 2 model B?
Ghanima
  • 15,958
  • 65
Bob
  • 41
You will need a new kernel, which should be installed on Raspbian regardless of model (meaning, you can do it on the B+) if you:
sudo apt-get update
sudo apt-get upgrade
If the Pi 2 then fails to boot but produces kernel error messages, edit config.txt in the first partition. Find the kernel= and change what's there to:
kernel=kernel7.img
If it doesn't exist, create it (but if it didn't exist I think it should have worked properly in the first place).
The kernel is currently the only difference for Raspbian; armv7 is backward compatible with armv6, so the userland works. This other pi distros should work the same way -- you just need an armv7 kernel. If there isn't one, you should be able to use the kernel7.img from Raspbian. Make sure you also install the modules, which means copying /lib/modules/3.X.X-v7 over (X.X is probably 18.5, the -v7 is what's important).
If you do want to use that route -- copying in a kernel and modules because you cannot or do not want to upgrade the OS -- see here about how to mount an SD card image to get the files out. Remember, the kernel will be in the first partition, the modules in the second.
In the element14 webpage (http://www.element14.com/community/docs/DOC-73878/l/raspberry-pi-2-model-b-frequently-asked-questions-faqs), you can find:
Will the microSD card and Operating System from my previous model of Raspberry Pi work with the Raspberry Pi 2 Model B? If you are using Raspbian, you will have to update it first. On your existing Raspberry Pi you can run the following commands from the terminal:
sudo apt-get update
sudo apt-get dist-upgrade
Alternatively, you can download the latest SD Card image from raspberrypi.org/downloads
