My SD card corrupted itself but I have a back up image.
The partition table leave 1GB unallocated space at the end so that I can restore to any 8GB memory card regardless of memory fluctuations.
The actual img file is 8GB. How can I shrink this down to ignore the extra space at the end so that I can write it onto a slightly smaller memory card?
wie5Ooma
  • 296
user2290362
  • 323
There is a nice tool available. Try pishrink
PiShrink is a bash script that automatically shrinks a pi image that will then resize to the max size of the SD card on boot. This will make putting the image back onto the SD card faster and the shrunk images will compress better.
framp
  • 896
After three days hands on researching with tools like fdisk, dd, resize2fs, lsblk and e2fsck, I find this VIDEO do the trick in a much faster and easier manner with gparted. I think you question is: "How to install a Raspberry pi linux system backup from a big SD card to a smaller one." :)
Gfast2
If you know for a fact that your 8GB image only has 7GB of allocated data (or less), you can tell dd to copy that exact amount to the new SD card. Here's a command to copy 7168 blocks of 1 Megabyte each:
dd if=/path/to/file.img of=/dev/sdX bs=1M count=7168
You should actually specify the exact size when creating your backups, which would also make them somewhat smaller.
There's absolutely no harm in not copying the unallocated data (i.e. garbage) from the image, as no sane system stores data outside the partitions.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
I ended up dd'ing it and ignoring the error about the destination being too small. Worked fine.
user2290362
  • 323
