(Using ubuntu 14 on a laptop) I followed this guide to set up my wifi by sshing into the pi via ethernet. I checked my routers networks settings and it showed two ip addresses from the pi, and I could ssh into the wireless address without a problem.
When I unlplugged the ethernet and restarted the pi the wifi address does not show up, and I can't ssh in.
I tried restarting it with and without ethernet with the same results. whats happening?
Here is my interfaces file:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-ssid "Patty likes oldman"
wpa-psk "analrapist"
iface default inet dhcp
Here is my wpa_supplicant.conf file:
update_config=1
network={
ssid="Patty like oldman"
psk="analrapist"
# Protocol type can be: RSN (for WP2) and WPA (for WPA1)
proto=WPA
# Key management type can be: WPA-PSK or WPA-EAP (Pre-Shared or Enterprise)
key_mgmt=WPA-PSK
# Pairwise can be CCMP or TKIP (for WPA2 or WPA1)
pairwise=TKIP
#Authorization option should be OPEN for both WPA1/WPA2 (in less commonly used $
auth_alg=OPEN
tkelly003
This applies to Raspbian Wheezy prior to 2015-05-05 for later (and Jessie) See How do I set up networking/WiFi/Static IP
This SHOULD work, but without seeing your /etc/network/interfaces it is hard to know.
I do not think this is the best option. I suggest /etc/network/interfaces should contain
allow-hotplug wlan0
auto wlan0
iface wlan0 inet manual
wpa-roam will keep trying to reconnect when it finds no wired network.
wpa-conf option will not keep reconnecting.
It is difficult to find the documentation for these commands.
