I was wondering how to change the gpio directory for the node.js pi-gpio library. Whenever I try to run the script to change the pin it returns this error:
"Error when trying to open pin 40
gpio-admin: failed to change group ownership of /sys/devices/virtual/gpio/gpio21/direction: No such file or directory"
Matthew Pitzer
  • 55
When the latest package raspberrypi-bootloader:armhf 1.20150130-1 was installed, the gpio symbolic links in /sys/class/gpio/ moved from /sys/devices/virtual/ to /sys/devices/soc/20200000.gpio.
Solution 1
chmod -R +x /sys/devices/soc/20200000.gpio
Solution 2
Update the pi-gpio.js so that
sysFsPath = "/sys/devices/virtual/gpio";
points to the new path:
sysFsPath = "/sys/class/gpio";
Solution 3
Add line device_tree= in /boot/config.txt. That will revert the links to be in the old path. Make sure you reboot after changing the config.txt.
Pick your flavor :)
Edit:
I've fixed both pi-gpio (pull request #34) and gpio-admin (pull request #7) in a manner so that both the old and the new paths are supported. Hopefully, those pull requests are merged soon...
Saran
  • 293
I had the same error as Matthew and after trying this solution I could see that Saran's fix had already been implemented into the "npm pi-pgio".
If you're still having this problem this solution worked for me. You need to update the path in gpio-admin.
First Download gpio-admin and open source code (I used nano, but any editor will do)
$git clone https://github.com/quick2wire/quick2wire-gpio-admin
$nano quick2wire-gpio-admin/src/gpio-admin.c
Check this file and make sure that the paths are updated. Update the function allow_access_by_user() the path needs to be updated to "/sys/class/gpio/gpio%u/%s"
Now navigate into the folder and install
$cd quick2wire-gpio-admin
$make
$sudo make install
Note: you may need to add yourself as a user
$sudo add adduser $USERNAME gpio
Hope this helps save some headaches!
Cody Wikman
  • 111
