I'm working on David Hunt's Touchscreen Pi Timelapse Controller (https://learn.adafruit.com/touchscreen-pi-timelapse-controller/overview) and have encountered some difficulty in the the hardware section of the instructions. I have a Raspberry Pi B+.
He specifies to connect to GPIO17, but this is being used by the PiTFT Touchscreen, which uses pins 1-26. I don't see another 3.3V power source that is not covered by the touchscreen. Is there a way to connect to GPIO17 with the Touchscreen on, or a way to get the power from another pin?
I'm really new to RasPi, so would appreciate some advice. Thanks!
Nathalie
  • 43
The 3V3 rail is only brought out on pins 1 and 17.
Your only choices appear to be
  • an external 3V3 power supply (but then you'd have the same problem connecting the grounds)
  • to carefully splice one of the 3V3 wires
  • to carefully solder an insulated wire to pins 1 or 17 on the underside of the board
EDITED TO ADD
There is another option
  • If the device needs only a little current at 3V3 (say 10 mA) use any accessible gpio and set it high.
joan
  • 71,852
  • 76
  • 108
