I´ve been trying to connect my raspberry pi to my laptop by creating an AD-HOC WiFi connection between them but it doesn´t work. Could anybody please help me out. Here is some information about the error:
pi@raspberrypi -$ iwconfig
lo       no wireless extensions.
eth0     no wireless extensions.
pi@raspberrypi -$ sudo /etc/init.d/networking restart
[warn] Running /etc/init.d/networking restart is deprecated because it may not re-enable some interfaces ... (warning)
[....] Reconfiguring network interfaces...wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to connect to wpa_supplicant - wpa_ctrl_open: no such file or directory
wpa_supplicant: /sbin/wpa_cli daemon failed to start
run-parts: /etc/network/if-up.d/wpasupplicant exited with return code 1
done.
pi@raspberrypi -$ sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network= {
         ssid="pissh"
         psk="raspberry"
         proto=WPA
         key_mgmt=WPA-PSK
         pairwise=TKIP
         auth_alg=OPEN
pi@raspberry -$ cat /etc/networks/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
auto wlan0
Hi if you are using EDIMAX 7811UN WiFi adapters you might as well have to change it since it does not support adhoc networking past Linux 3.9+ kernel versions.
For further details check this query
Though I use Hardcoded Static Addresses and not wpa-supplicant but this is likely due to hardware incompatibility
Major UPDATE
with Debian Wheezy 7.10 firmware update, the EDIMAX adapters are now ad-hoc mode compatible which makes them ubiquitous for any mode of WLAN. This has been checked and tested by me personally!
Shan-Desai
  • 1,541
  • 28
This applies to Raspbian Wheezy prior to 2015-05-05 for later (and Jessie) See How do I set up networking/WiFi/Static IP
You need the last line below to get an IP address. Normally you have auto wlan0 before wpa-roam (although it probably doesn't matter)
allow-hotplug wlan0
auto wlan0
iface default inet dhcp
