I have just got a Raspberry PI B+ and I don't really know how to set it up. I have read some guides and they say that you need a monitor and a mouse, I only have a laptop.
Can someone please help me with setting up a raspberry pi b+ with just a laptop, I do have a micro SD card and mainly all of the required things, I just don't know how to do it with a laptop.
Chetan Bhargava
  • 1,252
  • 29
Random guy
I'd comment (reputation)
Connect your pi to your router via ethernet cable.
If you're using OS X, you can open the Airport Utility to view the settings and wireless clients connected which will also show the IP address os the pi
If not you can use a multitude of commands to view the same details above on other OS's/network setups.
Then simply run this in your terminal/cmd:
ssh pi@The_IP_Address
Then enter the password:
raspberry
raspberry is the default password
1''
  • 246
It's far easier with a keyboard and screen.
I don't know how a NOOBs install will work. If you have the Raspbian image written to the SD card you could try the following.
  1. Connect the Pi to a router with an Ethernet cable. This assumes that your laptop is also connected to the router via wireless or cable.
  2. Power the Pi. You should see a minute or so of green LED activity.
  3. Login to the router and check to see if the Pi has been assigned an IP address, say 192.168.0.23.
  4. Use putty (Windows) or ssh (Linux) to log in to the Pi from the laptop, e.g. ssh pi@192.168.0.23 (password raspberry).
Good luck.
joan
  • 71,852
  • 76
  • 108
See my answer on another question : https://raspberrypi.stackexchange.com/a/4065/3290
Some linux distro, such as Occidentalis, have a avahi daemon configured, so you don't need to know the IP address to connect to the raspberry.
As you have indicated in your comments you are inclined to use Raspbian. If you want to use raspbian, Follow this:
  1. Download and image latest raspbian on SD card - Guide
  2. Mount the SD card in Linux (assuming your laptop has Linux or a VM with Linux) and edit the /etc/network/interfaces file assuming 192.168.10.110 is the IP you want to assign and 192.168.10.1 is your gateway.
#iface eth0 inet dhcp
iface eth0 inet static
address 192.168.10.110
netmask 255.255.255.0
gateway 192.168.10.1
  1. Safely unmount the SD card and insert into the Pi
  2. Connect ethernet cable to your pi and power it up
  3. ssh into the Pi using your laptop
ssh pi@192.168.10.110
  1. If you would like to use graphical applications in raspbian, you can install Xserver on your laptop and use X11 forwarding with ssh.
This way you can avoid using a monitor, keyboard and mouse to setup your Pi.
Chetan Bhargava
  • 1,252
  • 29
