I am wondering if it is possible to send 9 data bits framed with a start/stop bit at 1.25MBaud.
I am currently using PySerial to configure the UART pins on the pi. I've stumbled across a few problems.
Pyserial requires you to send in ascii to the port, which is 7 bits, however can be converted into a byte with a leading serial using bytes(data.encode("ascii")
Pyserial does not seem to like 1.25MBaud
Any advice to maximize speed and configurability of the UART pins would be appreciated!
Steve Robillard
  • 34,988
  • 106
  • 110
SerialMadMan
The serial driver (see stty, man stty) only supports 5-8 data bits.
The nearest standard serial speed is 230400.
You can get 1.25 Mbps by using the init_uart_clock setting in /boot/config.txt (set it to 16 times the maximum value you want to use, i.e. init_uart_clock=20000000). stty will then let you select 1250000 bps.
I'm not aware of a practical solution for the 9 data bits. I've read of people trying to use the parity bit as an extra data bit.
joan
  • 71,852
  • 76
  • 108
I have experimented and have a sort of solution to sending 9-bit data at 1.25 Mbps.
It involves modifications to my pigpio library.
I've added a gpioWaveAddSerialX() function which extends the gpioWaveAddSerial() function to allow for setting the number of data bits. This function constructs a waveform representing the serial data to be transmitted.
This also required an update to the internal waveBitDelay() function to allow for a variable number of data bits.
The other needed change was to change the base clock from 1 MHz to 1.25 MHz by changing clkDivI = 50 * micros to clkDivI = 40 * micros in the internal initClock() function.
The manifest constant PI_WAVE_MAX_BAUD in pigpio.h was changed to 1000000.
9-bit data 1.25 Mbps overview 9-bit data 1.25 Mbps detail
waveBitDelay
static void waveBitDelay(unsigned baud, unsigned bits, unsigned *bitDelay)
   unsigned fullBit, halfBit, s, e, d, m, i, err, t;
   /* scaled 100X */
   fullBit = 100000000 / baud;
   halfBit =  50000000 / baud;
   d = (fullBit/200)*200;
   s = 0;
   e = d;
   t = d/100;
   bitDelay[0] = t ? t : 1;
   err = d / 3;
   for (i=0; i<bits; i++)
      s = e;
      m = halfBit + (i+1)*fullBit;
      e = s + d;
      if ((e-m) < err) e+=200;
      t = (e-s)/100;
      bitDelay[i+1] = t ? t : 1;
   s = e;
   e = ((100*(bits+2)*1000000 / baud)+100)/200*200;
   t = (e-s)/100;
   bitDelay[bits+1] = t ? t : 1;
gpioWaveAddSerialX
int gpioWaveAddSerialX
   (unsigned gpio,
    unsigned bbBaud,
    unsigned bbBits,
    unsigned offset,
    unsigned numChar,
    char     *bstr)
   int i, b, p, lev, c, v;
   uint16_t *wstr = bstr;
   unsigned bitDelay[17];
   DBG(DBG_USER,
      "gpio=%d baud=%d bits=%d offset=%d numChar=%d str=[%s]",
      gpio, bbBaud, bbBits, offset, numChar, myBuf2Str(numChar,
      (char *)bstr));
   CHECK_INITED;
   if (gpio > PI_MAX_USER_GPIO)
      SOFT_ERROR(PI_BAD_USER_GPIO, "bad gpio (%d)", gpio);
   if ((bbBaud < PI_WAVE_MIN_BAUD) || (bbBaud > PI_WAVE_MAX_BAUD))
      SOFT_ERROR(PI_BAD_WAVE_BAUD,
         "gpio %d, bad baud rate (%d)", gpio, bbBaud);
   if (numChar > PI_WAVE_MAX_CHARS)
      SOFT_ERROR(PI_TOO_MANY_CHARS, "too many chars (%d)", numChar);
   if (offset > PI_WAVE_MAX_MICROS)
      SOFT_ERROR(PI_BAD_SER_OFFSET, "offset too large (%d)", offset);
   if (bbBits > 8) numChar /= 2;
   if (!numChar) return 0;
   waveBitDelay(bbBaud, bbBits, bitDelay);
   for (i=0; i<=bbBits+1; i++) DBG(0, "bit%d delay=%d", i, bitDelay[0]);
   p = 0;
   wf[2][p].gpioOn  = (1<<gpio);
   wf[2][p].gpioOff = 0;
   wf[2][p].flags   = 0;
   if (offset > bitDelay[0]) wf[2][p].usDelay = offset;
   else                      wf[2][p].usDelay = bitDelay[0];
   for (i=0; i<numChar; i++)
      p++;
      /* start bit */
      wf[2][p].gpioOn = 0;
      wf[2][p].gpioOff = (1<<gpio);
      wf[2][p].flags   = 0;
      lev = 0;
      if (bbBits < 9)
         c = bstr[i];
      else
         c = wstr[i];
      DBG(0, "i=%d c=%x", i , c);
      for (b=0; b<bbBits; b++)
         if (c & (1<<b)) v=1; else v=0;
         if (v == lev) wf[2][p].usDelay += bitDelay[b+1];
         else
            p++;
            lev = v;
            if (lev)
               wf[2][p].flags   = 0;
            else
               wf[2][p].flags   = 0;
            wf[2][p].usDelay = bitDelay[b+1];
      /* stop bit */
      if (lev) wf[2][p].usDelay += bitDelay[9];
      else
         p++;
         wf[2][p].usDelay = bitDelay[9];
         wf[2][p].flags   = 0;
   p++;
   wf[2][p].flags   = 0;
   return rawWaveAddGeneric(p, wf[2]);
Test program.
#include <stdio.h>
#include <stdint.h>
#include <pigpio.h>
#define GPIO 14
int main(int argc, char *argv[])
   uint16_t buf[1024];
   int i, wid;
   if (gpioInitialise() < 0) return 1;
   gpioSetMode(GPIO, PI_OUTPUT);
   for (i=0; i<600; i++) buf[i] = i;
   gpioWaveAddSerialX(GPIO, 1000000, 9, 2, 0, 1200, (char*)buf);
   wid = gpioWaveCreate();
   if (wid >= 0)
      printf("ready recorder, then return\n");
      getchar();
      if (wid >= 0) gpioWaveTxSend(wid, 0);
      printf("stop recorder, then return\n");
      getchar();
   else printf("error %d\n", wid);
   gpioTerminate();
joan
  • 71,852
  • 76
  • 108
