I just bought a heat sink kit for my pi and I'm using Raspbian and would like to monitor the temperature continuously every 3 seconds via SSH while I perform tasks on the pi so that I don't have to keep manually entering in a command to display the current temperature, how do I do that?
I think using watch command is much easier, for example:
watch {your command}
In your case, it will be:
watch vcgencmd measure_temp
That will refresh by 2 seconds, if you want to define the interval by yourself (5 second maybe), you can type:
watch -n 5 <your command>
watch -n 5 vcgencmd measure_temp
You can cancel that with Ctrl+C.
- 4,353
- 10
- 32
- 43
- 111
- 1
- 2
The command for viewing the current temperature is found in this post: https://raspberrypi.stackexchange.com/a/1847/22221
To automate this such that you can view the temperature every 3 seconds without entering new commands can be accomplished by writing a simple shell script that has an infinite loop:
#!/bin/bash
echo "Press [ctrl+c] to end monitoring"
echo ""
while true
do
sleep 3s
done
Place that text in a file called monitor-temp and place it in ~/bin/ (if !/bin/ doesn't already exist, then just create it with mkdir ~/bin). Make monitor-temp executable: chmod 755 ~/bin/monitor-temp. End your terminal (or ssh) session and start a new one. Now you can run monitor-temp from any location in the file system via ssh or directly on the machine and you'll see something like the following:
pi@raspberrypi ~ $ monitor-temp
temp=48.7'C
temp=48.7'C
temp=49.2'C
temp=49.2'C
temp=48.7'C
If you want a few more bells as whistles, see the following script:
#!/bin/bash
for count in $(seq 1 100); do
echo -n "$(vcgencmd measure_temp | echo "$(sed -E 's/.([0-9][0-9].[0-9])./\1/g')" | echo "$(xargs)1.8" | bc | echo "$(xargs)+32" | bc | echo "$(xargs)'F / $(vcgencmd measure_temp | sed -E 's/.([0-9][0-9].[0-9]).*/\1/g')'C")\r"
sleep 3s
done
The main benefit of this script is that the line carriage is removed so that you don't overflow your terminal window with new lines. Additionally, the temperature in F and C is displayed.
Sample output:
94.1'F / 35.0'C
This will terminate after 100 checks but can easily be modified to run indefinitely if preferred.
I created the following alias for this script in my ~/.bash_profile:
alias temp="sh temp_script.sh"
NOTE: The removed carriages returns only works when executing via "sh" command (i.e. executing script via ./temp_script.sh does not respect the \r special character for some reason). Also, there is some redundancy in the echo command, but I made the tradeoff of having it be a one liner. Lastly, Fahrenheit conversion is a bit wonky and doesn't match up perfectly, although the input formula should be correct.
- 11
- 1
