So, basically, I've been trying to get my raspberry pi to get the room temperature from a DS18B20 1-wire temperature sensor.
I've read only GPIO 4 is capable of this, and I think for some reason GPIO 4 is not working.
I've tried connecting the sensor there, it is connected as it should, I've been checking the connections since I connected the sensor and couldn't read it...
I've tried connecting an led (using the proper resitor) to GPIO 4 and using wiringpi to turn it on and off, but I got nothing...
My question is, is there a way I can know for sure if the pin is okay and it is just some software issue?
NOTE: I don't really know how this is supposed to work, but when I do:
~ $ cd /sys/class/gpio
~ $ ls
What I get is:
export  gpio17  gpio18  gpio21  gpio22  gpio23  gpio24  gpio25  gpiochip0  unexport
The GPIO 4 doesn't show up... Now, I don't know if only the pins in use show, but if that's the case, none of the above should show, because i'm not using any pins right now...
EDIT: I have connected the DS18B20 like it says in the datasheet, like in this picture: DS18B20 Pinout
For the modules I have loaded:
modprobe w1-gpio
modprobe w1-therm
Superuser privileges, obviously.
I also tried:
modprobe w1-gpio pullup=1
modprobe w1-therm super_pullup=1
When I try:
sudo echo "4" > /sys/class/gpio/export
I get:
echo: write error: Device or resource busy
Just tried the pigpio test program and the results are:
Skipped non-user gpios: 0 1 28 29 30 31
Tested user gpios: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
Failed user gpios: None
I assume it is supposed to skip those non-user pins, right? Other than that I have no doubts about all the pins working... Which intrigues me, because I still can't read temperature...
I'm at work, I will take the pi home and test it there again with a simple LED turning on and OFF, if I discover anything, I will post it here...
I've been experimenting a lot with the pi, it is probably cluttered with stuff I wanted to test but never really used, do you think it would be wise to try a fresh Raspbian install?
Ghanima
  • 15,958
  • 65
Antero Duarte
  • 171
I had the same problem when working on a friend's model-B pi. We tried simply turning on an LED with GPIO 4 as you did and nothing happened. Fortunately, we found a solution here.
We ended up having to edit the /boot/config.txt file and added the line at the bottom of it:
dtoverlay=w1-gpio,gpiopin=4
Then rebooted, and were able to find the sensor and read from it. Hope this helps!
Ghanima
  • 15,958
  • 65
tdan1101
I guess you have loaded the kernel modules for 1-wire: sudo modprobe w1-gpio pullup=1 and sudo modprobe w1-therm.
GPIO4 should show up if you export that pin: echo β€œ4” > /sys/class/gpio/export and echo β€œin” > /sys/class/gpio/gpio4/direction.
Path to 1-wire data is something like /sys/bus/w1/devices/xx-xxxxxxxxxx/w1_slave.
user236012
  • 670
Problem solved.
I found online that I had to change the raspi.list file to read "deb http://archive.raspberrypi.org/debian/ wheezy main untested" and then run apt-get update and apt-get upgrade.
Then running:
cd /sys/bus/w1/devices
ls
:devices listed here, serial number should be something started with 28-0000:
After trying this, I was successful and I can read the 3 sensors.
I'm posting this answer as a reference if someone bumps into this question, thank you all for your help anyway :)
Antero Duarte
  • 171
