I'm trying to write a simple program to communicate between the RPi and a bluetooth cellphone. I went with this tutorial: Bluetooth Python tutorial for RPi and was able to connect to the phone and they bounded correctly. Then I wrote this python script:
#! /usr/bin/python
import serial
from protocol import *
from MotorControllerP import *
def startBluetoothServer():
        bluetoothSerial = serial.Serial("/dev/rfcomm1",baudrate=9600)
        print("Bluetooth connected")
        try:
                while 1:
                        data = bluetoothSerial.readLine()
                        if not data: break
                        data = data.decode()
                        print("Data received: "+data)
                        if data[:3] == Client.INIT_HEY:
                                print("Initiallizing connection")
                                bluetoothSerial.write((Server.INIT_OK+"\n").enc$
                                print("Connection initiallized")
                        elif data[:3] == Client.KTHXBYE:
                               bluetoothSerial.write(Server.CLOSE.encode())
                                exitAndClean()
                        elif data[:3] == Client.CUSTOM_MOVE:
                                data = str(data)
                                formattedData = data.split(",")
                                direction = formattedData[1]
                                left = formattedData[2]
                                right = formattedData[3]
                                response = customSpeed(direction,left,right)
                                print(direction+","+left+","+right)
                                bluetoothSerial.write((str(response)+"\n").enco$
                        else:
                                print("Command not understood: "+data)
        except KeyboardInterrupt:
                print("Rage Quit")
        except:
                print("Error happened:",sys.exc_info())
        finally:
                exitAndClean()
The code is supposed to read a command from the BT device and send it to a Motor controller. But I receive this error:
  File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
    self.run()
  File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
    self._target(*self._args, **self._kwargs)
  File "/home/pi/Desktop/Car/RPiCar/BluetoothServer.py", line 7, in startBluetoothServer
  File "/usr/lib/python2.7/dist-packages/serial/serialutil.py", line 260, in __init__
    self.open()
  File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 280, in open
    self._reconfigurePort()
  File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 409, in _reconfigurePort
    termios.tcsetattr(self.fd, TERMIOS.TCSANOW, [iflag, oflag, cflag, lflag, ispeed, ospeed, cc])
error: (5, 'Input/output error')
Any thoughts?
Javi
  • 203
Possibly you don't have /dev/rfcomm1. I suggest to use python-bluetooth library. Check this: example usage
Mert Gülsoy
  • 121
