I just setup my raspberry pi with the gertduino and I tried the given blink example. It works fine and now I wanted to use the rtc from the gertduino to set the time from the raspberry. How ever I installed i2c-tools and when I use i2cdetect the table shows 2 entries both UU in 20b and 30b. Now I just wanted to use the command:
sudo hwclock -r
and the response is:
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method
I would be really happy if anyone could give me some suggestions or maybe someone had the same problem configuring the rtc. Cheers Max
Max
  • 203
Found the answer. It was a mistake in the setup file.
Max
  • 203
