I did a bunch of work with my raspberry pi about a year ago. I got busy with other projects, but have started to work with the pi again. I somehow set my IP address to 192.168.1.123, but I don't see how this is happening. I check the configuration settings on my router, and it says 192.168.1.123 has a dhcp lease on its IP. I check /etc/network/interfaces, and it has no reference to static. If I cycle the power on the pi, each time the IP address gets assigned the same value, as if it was static. How is this possible? Could it be that my router associates the MAC address of my pi with a static IP I assigned in a previous version of /etc/network/interfaces?
Here is the current version of /etc/network/interfaces
pi@raspberrypi ~ $ cat /etc/network/interfaces auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
Here is /etc/wpa_supplicant/wpa_supplicant.conf
pi@raspberrypi ~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="LFI92"
key_mgmt=NONE
auth_alg=SHARED
wep_key0=3f8blahblahblah
hairyberry
  • 41
Your original configuration using DHCP was most likely fine. You could use a DHCP Reservation to tell your router to issue a particular IP address to your Raspberry Pi every time, rather than using static IP addresses which can cause other issues.
DHCP = Dynamic Host Configuration Protocol, and is the method your network router uses to hand out IP addresses those devices on your network which are configured to use DHCP.
IP addresses are leased by your network router to each device. After a period of time (e.g. 7 days) if the IP address is no longer being used it is returned to the pool so another device can use it.
When set to use DHCP your Raspberry Pi is asking for an IP address and your router responds with one.
You can tell your router to always assign your Raspberry Pi the same IP address, by setting up a DHCP reservation. This will bind an IP address to the MAC address of your device (your Pi).
Setting up a DHCP reservation is usually fairly easy, as long as you have access to your router. The advantages are:
  • Settings are automatically configured by your router including subnet mask, default gateway and DNS servers - all important for network and Internet access from your Pi
  • Accidental IP address conflicts are avoided, so another device won't be given the same IP address as your Pi
  • Connecting your device to another network won't require you to reconfigure it
Chris
  • 131
I had an issue in having multiple/more than one WiFi router i wanted to connect with, and to each router with different subnet, ip, ...
Here is the trick:
First to establish connection with WiFi (negotiate protocols, pass), you have 2 options: 1) do it through GUI tool:
  • WiFi config
  • Current Status
  • Scan
  • Double click the network
  • provide pass
  • save it
  • Manage Networks
  • IDString: [b][/b]
  • Priority: 0
  • File -> Save Configuration
2) Do it manually (you have already abovementioned advice from other users). This is what i did set: sudo joe /etc/wpa_supplicant/wpa_supplicant.conf
network={
    ssid="Chupavi D-Link"
    psk="xxx"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    auth_alg=OPEN
    id_str="wifi_oslo"
network={
    ssid="rudani"
    psk="xxx"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    auth_alg=OPEN
    id_str="wifi_bg"
You will notice that there are TWO networks, and that PSK is the pass that you set to your own pass, same as SSID and other parameters. ID_STR you also choose.
Finally you have to provide IP parameters:
sudo joe /etc/network/interfaces
iface wifi_oslo inet static
    address 192.168.0.125
    netmask 255.255.255.0
    gateway 192.168.0.1
    network 192.168.0.0
    broadcast 192.168.1.255
iface wifi_belgrade inet static
    address 192.168.2.125
    gateway 192.168.2.1
    network 192.168.2.0
    broadcast 192.168.2.255
You can see that you simply refer to ID_STR you created in the first step and set any IP parameters you want.
Good luck!
mPrinC
  • 121
I decided to set up a static IP address for wlan0. Here is the new version of /etc/network/interfaces
auto lo
allow-hotplug wlan0
auto wlan0
iface wlan0 inet static
address 192.168.1.123
network 192.168.1.1
broadcast 255.255.255.255
gateway 192.168.1.1
mpromonet
  • 1,124
  • 38
hairyberry
  • 41
