9
I have a repo that causes an error to appear whenever i update or install anything.
How can i remove it?
Error message
W: Failed to fetch http://repo.offensive-security.com/dist/bt4/binary/en_GB  Unable to connect to repo.offensive-security.com:http:
Dan Cundy
  • 195
What worked for me:
  1. Check your /etc/apt/sources.list and remove unwanted sources.
    sudo nano /etc/apt/sources.list
  2. If step 1 does not solve your problem, see what other sources are used:
    sudo ls -al /etc/apt/sources.list.d/
  3. If you have found a source-list causing the problem, remove it (in the example below, NodeJS source list is removed):
    sudo rm /etc/apt/sources.list.d/nodesource.list
Quintin B
  • 689
To change the apt repository list you need to edit /etc/apt/sources.list.
If this answer does not solve your problem, please edit your question and paste the content of /etc/apt/sources.list.
Use sudo nano /etc/apt/sources.list in the terminal and then delete the lines corresponding to the unwanted repository.
RPiAwesomeness
  • 3,021
  • 52
Morgan Courbet
  • 3,703
  • 38
OK THis is major: If you are unable to download the Pi2 version, edit (Nano) the list file(s) in etc/apt/sources.list.d folder. THere will be an line YOU MUST CHANGE to get the files into your repository. "arch=amd64" MUST BE CHANGED TO "arch=armhf". THen check the repository list with "sudo apt-cache policy AppNameHere". If you dont have the names of the downloads, you've done it wrong.
